sound like a diesel when i start
Old Nov 24, 2003 | 05:03 PM
boutch's Avatar
sound like the chain, but i don't no if i need to change all the timing chain or just the tensioner. i have a 95 max.
Old Nov 24, 2003 | 06:08 PM
nick's Avatar
more details would make the troubleshooting much easier ...
does it go away once the engine gets warm?
did you try to listen to various parts of an engine to pinpoint the location of the sound ?
I have similar sound - but it is an exhaust leak for sure somwhere is the ERG vaccum area
or it could be O ring from Budget Y-pipe not sealing corectly when cold , once it gets worm it expands thus creating tight seal
do some basic listening with long screwdriver next to your ear , than come back with results
we will keep this thread alive !!!
this is one noise i can not fix - but i'm not giving up on it.
also good old saying goes " if aint broke - dont fix it"
I look at this that way - car still drives !!!
Nick
Old Nov 27, 2003 | 03:34 PM
95-96Maximas's Avatar
If it goes away after startup - then it may be your starter. There are secret recalls on them (they replace repalce them for oyu at a discount!)
Old Nov 27, 2003 | 03:35 PM
If it goes away after startup - then it may be your starter. There are secret recalls on them (they replace them for you at a discount!)
Old Nov 28, 2003 | 03:33 PM
Kevlo911's Avatar
Kevlo for President
i just got this noise too, it was after a cold start it lasted 2 sec. it does not happen on warm starts. first time it ever happened. i use mobil1 and a nissan filter. what could it be?
Old Nov 28, 2003 | 05:22 PM
Kevlo:
Yep it almost always sounds like no oil pressure - like valves making noise. I had it for a while - only when it is cold - I took car to dealer - left it overnite - it is the starter.
Old Nov 29, 2003 | 05:40 AM
Kevlo911's Avatar
Kevlo for President
should i change the oil pressure switch?
DJLAX152
May 4, 2021 11:46 AM
97_GXE
Sep 15, 2015 06:47 AM
carid
Sep 9, 2015 05:06 AM
