Can I use 97-01 SE steering wheel on a 96?
Originally Posted by vsamoylov
no, connectors for cruise control is different. I really don't like the fat ones cause they are not comfterable.
Originally Posted by 190hpKiLLA
ok lets say i will sacrafice the cruise control. Can i do it then?
yes, the airbag is different, the wheel, and the connector to the cruise control. I did it with my moms car. Her bag was deployed and i had a 1997 i30 sterring wheel with airbag and put that it. everything worked except the cruise.
Originally Posted by nupe500
You ARE correct the connectors for the cruise as WELL as the airbag are different, but it can be done by simply removing the ENTIRE wiring harness from the interior of a 97, which involves gutting the entire car...then you have to take apart the little module behind the steering wheel...it has airbag stuff on it...and replace it with the 97, to get everthing to work properly. I got everything to work for me for a day and a half but think that I've blown a fuse somewhere, so no worky...but the steering wheel fits and looks and feels much better than the stupid 95 gxe wheel I had in there...oh...airbag for sale too...hit me up!
Only the cruise control connector is different?
or
Both the AIRBAG & Cruise is different.
Vecause If i have to gut the whole car for the airbag to work I wont do it. But ifs its the cruise control then i dont care if it works or not.?? Please respond...
wouldn't a wheel cover do the trick? Takes care of the "skinny" quality at least.
These look good:
www.wheelskins.com
here's a half-shot of my $9 wheel cover. Feels good and the side trim matches my seats so
http://207.236.3.100/IMG_0017.JPG
Bill.
These look good:
www.wheelskins.com
Bill.
probably the connectors but the color of the wires might be different also. you should ask somebidy that has a 99 max what colors the wires are to see if they are the same as yours and use a voltmeter to check if they give a different reading also. research
Ok for the cruise, the connectors are different but both only have 3 wires:
95-96 models:
______________
|_1_|_2_|_3_|_X_|
97-99 models:
___________________
|_1_|_X_|_3_|_X_|_2_|
so my guess is just the connectors are different u just need to re-arrange the wires.!
95-96 models:
______________
|_1_|_2_|_3_|_X_|
97-99 models:
___________________
95-96 models:
______________
|_1_|_2_|_3_|_X_|
97-99 models:
___________________
95-96 models:
______________
|_1_|_2_|_3_|_X_|
97-99 models:
___________________
What about AIRBAG wires?? are they plug and play. I need to know this because Im getting a steering wheel with airbag of a 00 SE.
Hate to burst your bubble, but the airbag plugs are definatly different...it maybe because my 95 was a GXE while all the parts came from my crashed 97 SE...could be jus the trim difference, but I know for a fact that they are different.
Well...I ended up completely rewiring my 95 to be a 97...so that solved my problems...I mean...I gutted both cars...and basically reconstructed the 95 to be a 97..only thing that is original 95 is the steering column, the doors, and the chassis
First off...
97-99 SE steering wheel and get the 97-99 cruise control switch.
THESE TWO ARE A DIRECT SWAP. Connectors are plug and play. You have to drill a hole out on the steering wheel alittle bigger to get it to fit over the clockspring right. THERE IS NO NEED FOR A COMPLETE WIRING HARNESS CHANGE.
EDIT : total cost for me was $300 bucks switch and airbag and wheel from another org member. Sometimes you just have to be a pioneer.
JoshG
51
Sep 21, 2015 10:41 PM
