Help. My parking brake light is always on
Originally Posted by Vlad
hmmmm, gotta ask - is you e-brake all the way down?
I believe there is also a switch beneith the e-brake, probably it got jammed??
Haha. Yes, my ebrake is all the way down and my TV is plugged in. There's a switch beneath the ebrake? Hmmm, I'll check that out. Anyone have any better instructions on how to find it, or is it pretty easy to find? Thanks.
Originally Posted by Nismo
Low fluid level and no sign of a leak indicates that your brake pads are worn out, better check your pads too
Wow I'm learning a lot here. How can I tell if my brake pads are worn? I didn't see anything about this in the how to/FAQ section.
yeah, if break fluid is low, light will stay on. that happend to me on 2 different cars when i was bleading my brakes. but i doubt that worn brake pads will signal a light. also if rear brake pads wear too fast, you e brake wire most be too tight. that happend to me also.
oddly enough, i had that problem a few months back and my fluid and pads were fine. it kept going on and off and then stopped for good. not sure what that meant cuz i brought it somewhere and they said everything looked fine...
cars (when they're not working right) drive me nuts.
yeah, i hate when cars get a problem. for example, i was driving my 96 max one day and out of nowhere my check engine light comes on. i was like ok, now what. first thing that came to my mind was speed sensor because of my new wheels because the computer finally adjusted to them so the light came on. But when I get home, i pull my scanner out, and plug it i. it says that evaporative gases from the canister were throwing a code. i deleted the code and never came back.
tsi6001
Oct 3, 2022 10:23 PM
so will keep in mind
