2002 modified max vs stock 2000 bmw Z3
what do you think about a 2002 maxima (high flow cat, injen intake, greddy cat back exhaust, v-tech power control module, drop resistor mod, stock 17" tires) ... im thinking about putting in stillen polished headers too, but anyway, against a 2000 bmw Z3 in a 1/4?
To answer your question, Yes you should be able to beat one pretty easily, auto or 6speed.
-Paul
it could be closer than you think. In the 1/4, I'd give the advantage to the Maxima cause we got more power than the Z3.
BTW, the Stillin headers have proven losses on the dynos... might want to consider that before buying them.
-Paul
You should beat the 2.8L Z3, (193HP) however i'd imagine the 3.0L would be more than a handful unless you were modded as it is rated at 225HP, however puts down ~5-10 less whp than a 2k2/3 Maxima and it's RWD...
LEMAR
LEMAR
they didnt have the 3.0 till '01.
contrary to popular belief...this Z3 is a beast. 14.0-.2 stock with a good driver...high 13s with a highly skilled driver...
good luck if you see a 3.0 on the streets in the hands of a skilled driver...now they put the 3.0 in the Z4...my good friend's dad's Z4 pulled on a S2000 bad on the highway...
.... if your referring to the 3.2 that is the MRoadster i believe which is the Mpowered engine - and we are definatly not talking about that here because i dont think it would have been referred to as a "z3" - anyways any 3.0 would be a good match - they are rated 225 HP at the CRANK and are alot less torquey at the low end - not to mention the curb weight is 2 lbs off from being a 3000lb car and our max is just 200 lbs over that which isnt a BIG deal.. anyways 3.0 should be a good race - anything below that engine i would give to the 3.5 - and im terribly sorry but any z3 rather than the mpowered version isnt going to hit 13's on the street ... and dont bring this "highly skilled driver" non-sense in here - you think the majority of the people in here can pull a close to 0.0 reaction time and a sub 2.0 sec 60 foot time here ... no.
Nintensity
Aug 13, 2015 05:41 PM
fastcarny
Aug 12, 2015 03:50 PM
jholley
Aug 11, 2015 09:38 AM
yat70458
Aug 3, 2015 01:16 PM
