what's a rubber spring seat?
I've been hearing noises from my suspension everytime i go over bumps and when the car sways ..it's sounds more like a sqeaky spring along with some crapping noises....found this on the internet:
"Noises from the right front strut require replacement of the rubber spring seat. (2000)"
So whats a rubber spring seat and can it be checked visibly to see if this is the problem?
The rubber seat sits on top of the spring. I doubt that is your problem, but it is hard to say.
I had a similar problem with my 4th gen when I installed the H&R's and I put a hose around the spring to stop the noise.
You would have to take it off to check the seat. How long have you had the springs?
I would say it is either the strut mount or you may have lost a isolation sleeve.
Have some turn the wheel while sitting still and see if you can narrow down the noise.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
