Engine Internals?
Old Feb 10, 2004 | 08:27 PM
Morfeus17's Avatar
Engine Internals?
I need some advice on recommended pistons and rods... And also recommended compression... Which one would be suited for about 20-30psi?? 8:1, 8.5:1, or 9:1?? I'm looking at the JE pistons, but I'm not sure on Rods.. Also the ring sets... How much are these and do the come with the piston set?
Also, is there gaskets for turbo applications for 4gen maximas?? Where would I get these?..
Finally, are there any recommendations on head bolts. Does APR make studs for our Maximas?
Thanks.
Old Feb 10, 2004 | 09:41 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
30 psi?? got traction? IMO go low...8.2 leaves plenty room for error, which will most likely be a greater factor when tuning for 20+ psi
Old Feb 10, 2004 | 10:34 PM
maximase86's Avatar
I love lamp.
Wow....20-30 psi....sounds a tad bit overkill to me. :P
S
Old Feb 10, 2004 | 11:07 PM
DAVE Sz's Avatar
Hooooooonda.....
holy ****! 30psi? Can we even run that much without blowing ourselves up? this ain't no DSM.
Old Feb 11, 2004 | 03:21 AM
C MAX's Avatar
Thanks.
hey what are you trying to do.. make me strap on a rocket to keep up with you .. 8:1 should be good enough, because you probably wont make 30PSI anytime soon. wow the thought is scary though...i hope you will have some extra diapers around for your passengers...
Old Feb 11, 2004 | 06:48 AM
Morfeus17's Avatar
Yeah 30psi is way to high. But I'm never planning to run that... Just want the internals to be rated for high boost. For both saftey and re-assurance.
Old Feb 11, 2004 | 06:50 AM
Morfeus17's Avatar
Yeah... You need more than dipers with that type off boost CMAX... Oh buy the way, I was able to fix my cooling problems long story... I'll tell you about it later..
Old Feb 11, 2004 | 07:28 AM
stephenlc's Avatar
Anything over 20psi, you are probally going to have to run some kind of race gas, or aqua mist setup. I think 9:1 compression is the lowest I would go. I think good tuning is the key hear. You probally have to spend 2000 on a stand a lone and soem good tuning. Pistons and rods will have to be custom, those should come with rings. Someone got some copper gaskets for there car, they were custom though and yes they make ARP head studs for our car.
Old Feb 11, 2004 | 02:52 PM
Morfeus17's Avatar
Yeah 9.1 compression seems decent. I'll do my homework on this... Thanks for the info...
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
