DAM BS Keyless remote!!!! please someone help
So I bought this remote on ebay, looks like the 95 version but a bit cleaner, I tried following the steps provided on the forum, with no luck. I emailed the guy telling him about it, and he said all remotes are checked and work and blah balh, to check with my dealership to see if the remote would work with my car. Its fuxking BS, its not a new 99-up remote it looks like a 95, (three basic buttons trunk, unlock, lock,) I swapped out the battery, did the lock the car procedure, finger the keyhole w/ key, put the car in ACC, press lock on the remote, I didnt get the flashin hazards. What else can it be???? Is the guy lieing to me??? THanks peace
I saw them, and I thought it looked cleaner, and nicer. But I bought one for the 95-98 I guess, its the basic one, the black one with the three buttons, I didnt go for the new ones, cause well I thought it wouldnt work,
There are no other ones except the 3 button ones. I have 2 extra ones and both programmed. The 99 has the same 3 button as the previous years. No others can be programmed by you to work with the stock alarm.
oh for reals, well the other ones I was talking about are 3 or 4 buttons (dont remember) red, and blue, I guess those are for the 2000's and up, SOB that sucks, so how the F**K do i get me a keyless remote? Sorry for the language, I pratically gave away $15 for a remote I cant use.
Originally Posted by Big D
Why can't you use it? Does it have a battery in it? How many times did you try programming it? It took me 2 or 3 times to do the first one cause the instructions aren't that great.
it might not match w/ your previous one
Yeah, I replaced the battery with a new one, and right size/model, I followed the instructions, I lock the doors, do the in and out thing with the key, hazards come on, tunr key to ACC postion, and then press lock on the remote. (I'm suppose to get the hazard lights again. but I dont) Am I missing anything???
http://forums.maxima.org/showthread....7&page=2&pp=30
thats the link, scroll down some, its posted by the moderator,
Did you lock all the doors with the one switch on the driver door? Make sure you don't turn the key to the on position onstead of the ACC. On is where the key stops right before the engine turns on. ACC is right after off. Don't know what else it could be.
yeah, I used both the switch on the panel, and the the door handle switch, ACC is right after you barely turn on the car, only your radio will turn on, after that turn alittle more and the , ac/radio, and your oil light, air bar, etc. lights come on. then after the full twist, the car starts.
all it says on the back of the remote is:
Ut automotive
FCC ID:KOBUTA3T
Canada: 1983 101 754
Use cr2025 battery
and the lock and unlock code
Ut automotive
FCC ID:KOBUTA3T
Use cr2025 battery
It doesn't sound like you have a 4th gen remote since as far as I know, all 4th gen remotes have 4 buttons. Max99ES is probably right.
1st gray one on the top half circle = lock
2nd = Unlock
3rd = Trunk
4th = Panic OR room lamp toggle
(If your 4th is a room lamp toggle, the 1st lock doubles as a panic when held down for about 2 seconds)
2nd = Unlock
3rd = Trunk
I've got one of each for my 1995 Maxima, they both work differently depending on which remote I have:
4th button that activates panic:
4th button that toggles room lamp (1st main button doubles as panic):
Here's an Altima remote (prior to 2002) that has 3 buttons only:
Originally Posted by jay_z
Does anybody sell those things new? Or can one only get one off eBay? I bought mine used from a dealership and I got 1 key and that's it. No spare key or remote..it sucks.
www.ebaymotors.com
Under parts and accessories
search for maxima remote
Abt $20+ will get it to your door shipped, for a used one.
You can buy it used from eBay or new from the dealer (atleast $60+ for each), but make sure you can use it on your GXE. Do you have the little flashing security light next to the cruise control switch?
I think on the GXE you had to buy the Convenience package or something. You can always add a good aftermarket one
ToTheMax305
Sep 23, 2015 09:11 PM
haha j/k
