Where to mount the probe
I placed mine just a few inches from the flange for the rear bank. Location is arbitrary. You need to get on a dyno with wideband O2, which I haven't done yet, and see what the temps are when you get the A/F right. If you put it way downstream, by the cat, you'll probably be looking at for a value a few hundred degrees cooler than if you put it right into the exhaust port. I think Mardisgras put his right up front, through the heat shield. I thought about that but decided to go here for simplicity since I had the Y pipe of during my turbo install.
http://members.***.net/jekremer/egtsensor.jpg
Location is most certainly not arbitrary.
The probe needs to be mounted as close the the exhaust port as you can get it.
Try this method:
http://www.theoldone.com/archive/whe..._EGT_probe.htm
Try this method:
Unclejunebug
Apr 2, 2016 05:42 AM
