Where to mount the probe
Old 02-16-2004, 05:22 PM
ymNA's Avatar
I'm going to install the EGT gauge and prode tomorrow, wonder where you guys put your prode?
ymNA is offline
Old 02-16-2004, 06:33 PM
¿Hablas Español?
joaquink's Avatar
I placed mine just a few inches from the flange for the rear bank. Location is arbitrary. You need to get on a dyno with wideband O2, which I haven't done yet, and see what the temps are when you get the A/F right. If you put it way downstream, by the cat, you'll probably be looking at for a value a few hundred degrees cooler than if you put it right into the exhaust port. I think Mardisgras put his right up front, through the heat shield. I thought about that but decided to go here for simplicity since I had the Y pipe of during my turbo install.
http://members.***.net/jekremer/egtsensor.jpg
joaquink is offline
Old 02-16-2004, 06:37 PM
Minister of Silly Walks
mzmtg's Avatar
Location is most certainly not arbitrary.
The probe needs to be mounted as close the the exhaust port as you can get it.
Try this method:
http://www.theoldone.com/archive/whe..._EGT_probe.htm
mzmtg is offline
Old 02-16-2004, 09:14 PM
nismology's Avatar
IIRC, the left bank runs slighly more lean than the right so you might wanna put the probe right after the front bank flange...
nismology is offline
Unclejunebug
04-02-2016 05:42 AM
Pnjboyzz
11-16-2015 12:27 PM
Pnjboyzz
10-07-2015 10:47 PM
sliptap
09-30-2015 05:57 AM
Quick Reply: Where to mount the probe
