Foglights no workie
Old Feb 19, 2004 | 07:30 PM
BlueC's Avatar
wat
Foglights no workie
I put in some MTEC ion crystal H3 bulbs into my foglights today, started up the car, and no light is coming out of them. What could be wrong? Everything is connect and placed back where it was before. They are the higher wattage ones, but people have used them before ok.
need help asap
Old Feb 19, 2004 | 07:41 PM
MAXEJA's Avatar
well you could hook up a volt meter to the plug which you connected into you assembly and see if that is producing any power.. if that is not then you either blew a fuse or a wire. If it is producing power its the way you hooked up the blub or a bad bulb, examine the filiment. Not sure how many watts the new blubs are too high might cause it to draw to much current.
Old Feb 19, 2004 | 08:13 PM
Nismotic's Avatar
Always sunny in philly
I had 2 Nokya artic white H3's and they BOTH burned out in less than a week. Stick with OEM.
Old Feb 20, 2004 | 03:17 AM
Tatanko's Avatar
Bacon Lover
bump 123456
Old Feb 20, 2004 | 12:03 PM
BlueC's Avatar
wat
Anyone know? They havent turned on once, I checked all the connections, everythings ok.
Old Feb 20, 2004 | 12:15 PM
JacksMax's Avatar
You get power to the bulbs and they dont light? It sounds like the bulbs may be bad? (you DID see if there was 12 volts to the bulb, right?)
Old Feb 20, 2004 | 12:23 PM
BlueC's Avatar
wat
I dont have the tools to check. My other guess was maybe the fuse is blown...? How do I check for that? Where can I get a new fuse if it is?
I really want to solve this as soon as possible, cause if the bulbs are bad, i need to send them back, they have a lifetime warranty (thank god).
Old Feb 20, 2004 | 12:41 PM
Brudaddy's Avatar
from my experience, I would stick with OEM...like chillinmax said.
Old Feb 20, 2004 | 12:44 PM
BlueC's Avatar
wat
Problem is, OEM is too dim, I need something that will be bright to come close to matching the brightness of my HIDs. My stock foglights werent even noticable on the ground, my HIDs are too powerful.
So thats why I picked up some MTEC bulbs, Ive heard they work great, and I need the yellow/amber light to help in snowy, fog, and rain conditions. Its more than a need than a want.
Anyone have a solution to my problem?
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
