installing y-pipe help
Yeah the wire is a grounding wire I think.
If you are unable to get the bolts off then try taking it to a muffler shop and having them loosen them. Then drive the car home. Make sure to use new bolts/nuts...as those sound to be pretty much toast and not reusable.
Originally Posted by Oblongshapes
I cannot get the cat bolts off, i have wd40'ed them and everything else... any suggestions, and is there supposed to me a wire going to one of those bolts!
Originally Posted by sadice
hey while we on the subject what type of bolts and nuts do we need ??? so i can purchase them before i try to get my y-pype instaled.....
1. u'll need 14mm deep socket + extention
2. u'll need to pull like a ****! i mean really go all out and twist those rusted 14mms even if you sprayed some WD40.
3. if u stil can't get it off, use a torque wrench. i don't recommend it cuz u mite break the stud.
the fun part about modding is actually doing the work. taking it to the muffler shop is aite, but kinda defeats the purpose of modding. sure you can get the WHP, but where is the accomplishment?
that's what the org. is for. DIY style man... you could save up those a lot of $$ just do it yourself. not to mention u'll have extra $$ to get other mods.
good luck
if u have any more questions feel free to ask...
good luck
Originally Posted by budha56
What's that? Do I get it from Walmart or Autozone?
just get the cat off even if you strip the stud. i used a socket and a foot long cheater bar(you attach this to the end of the socket and use the extra leverage) i ended up really messing up the stud but i took my dremel tool and cut the stud off, then got my drill and some lubricating oil(its a must when drilling into metal i dont remember what its called but home depot has it) I just drilled out the stud in 10 min and got new slightly bigger bolts that fit that hole. just remember its not the end of the world if u strip the stud. but if you cant get the bolts off the cat with a cheater then i dont know what to tell u.
MaxLife17
Jun 27, 2019 01:37 PM
Violator
Sep 9, 2015 10:14 AM
If I were to torch it off or cut off the bolt, can you easily replace the thread too? or are they welded to the cat?
