OIL return problem.
Old Feb 26, 2004 | 11:28 AM
20th maxstyle's Avatar
OIL return problem.
It seems as though the oil return line leaks a bit. I think it is do to the build up of oil to the pan. Does anyone recomend anything such as an oil catch can or oil pump to do so? Has anyone gone through this?
Thanks.
Old Feb 26, 2004 | 01:40 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Thanks.
where is it leaking from?
that will be a good start to help determine the cause of the leak.
Old Feb 26, 2004 | 06:49 PM
vortechpower's Avatar
[QUOTE=bags533]where is it leaking from?
that will be a good start to help determine the cause of the leak.[/QUOTE
the return line from the blower is made out of rubber, you might have a tear where the metal clamp tightens around the hose and connect to the meta return. or what i thought was a leaking oil return line turned out to be the drive chain case leaking oil from the bolts that connects the bracket. are you getting oil on your belt?
Old Feb 26, 2004 | 07:23 PM
The end that connects to the turbo fiting. But the fitting is not leaking. It seems like it is leaking from the hose clamp. like the oil in the pan is causing preasure and won't allow the oil to drop down again, so it pumps out.
Old Feb 26, 2004 | 07:24 PM
THe Oil lines are now where near the belts.
Old Feb 26, 2004 | 07:52 PM
pimpjuice's Avatar
Might sound obvious, but did you check for any kinks in the return line?
Old Feb 26, 2004 | 08:10 PM
Bags's Avatar
The crimp that connects the fitting to the hose?
Remove your oil return line and dump oil in it, if it flows then there should not be a problem
When the car is running the oil sending unit should be pumping oil.
What size feed line do you have?
Who tapped your line?
Where does it feed?
What size is it?
Is it leaking out of your turbo? It almost sounds like it may be
Sorry for all the questions, just trying to help eliminate all the possible problems
And vortech power thought you had a supercharger
Old Feb 26, 2004 | 11:04 PM
NO SC i got rid of it. not me. Gots to have the turbonious. you know?
Return line. Same as stillen SC return line, but longer. and goes to the side of the oil pan (tapped).
Feed line. Same as stillen SC feed line, but longer. Flow was tested, does well. Remember, i had an SC kit.
Old Feb 27, 2004 | 08:39 AM
Bags's Avatar
Hmm.. what size is in the stillen kit? 6AN? 8AN?
Your turbo is doing more to your oil than the SC and it has farther travel.
Good thing you flow tested it!! I bet you did that before you installed the turbo..lol
Old Mar 2, 2004 | 07:51 AM
little late but my bad, yup i thought we were talking s/c
Old Mar 2, 2004 | 10:45 PM
Thanks to everyone. I bought a better Return fitting to my turbo that is ribben for it's pleasure. It did the trick.
Old Mar 2, 2004 | 11:24 PM
Bags's Avatar
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
