urgent help, Caliper won't go back in
I was changing my rear rotors today and my pass. side caliper won't go back in, I know I have to turn them to get it back in, but it just won't, I have the brake oil reservior uncaped but still won't do it, it will turn, but that s about it, help!
thanks
thanks
1. Make sure the parking brake cable is disconnected
2. Blast the piston with penetrating oil (PB Blaster, WD40, etc)
3. Using needle-nose pliers (or the special tool), very carefully turn it until it "breaks loose" (hopefully it will)
Maybe you can work it a little by pulling the lever which is normally operated by the parking brake cable... it should force the piston to move outward, try working that lever once to see if it loosens up.
thank for the quick reply
Originally Posted by Max2000
Parking brake cable is disconnected and like I said, I CAN turn the piston, but it just won't go back in..... any other advice?
It does take a lot of turns to get it in...
yes, I am putting inward pressure on the piston... I will give it a try again...
If you have questions e-mail me at: dblea@videotron.ca
Cheers
AA
thank you all for the answers... I did manage to get the piston back in. What I did was turn on the car, fully depressed the brake padel, so the piston came all the way out. then I turn it, it went back in. Needless to say, I am reliefed... again, tahnks all for the quick answer.
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
BobMax
Aug 15, 2015 12:35 PM
RealityCheck
Aug 5, 2015 06:18 AM
