So i got bored this weekend and decided to change the leds in my switches...
Pulled up the How-To by Alex Hsu and it looked simple enough. Thanks for the write-up btw. But i didn't want my PS window switch a different color than the PS lock switch. So i figured i'd take a shot at the window switch. Not too hard, just have to be careful and a little patient. So what do you guys think?
Driver's side
Passenger side
Driver's side
Passenger side
Driver's side
Passenger side
Driver's side
Passenger side
Originally Posted by BioMaxDDS
where is the writeup?
looks nice
looks nice
Originally Posted by PearlWhtMaX2000
where did u get the write up?
http://www.max-world.org/frames/howtodo.html
look under electrical
I pasted the direct link...nothing there:
http://68.193.158.145:1024/images/te.../ds_switch.jpg
http://68.193.158.145:1024/images/te.../ps_switch.jpg
^does this work for you?^
Driver's side
Passenger side
Driver's side
Passenger side
Originally Posted by soonerfan
how did you do the passenger window switch?? i tried to do mine and had springs and ball bearing everywhere. AND the bulb is diffirent. now i have a broken switch that is still green!!!
I removed the existing bulb and that green rubber holder. then i soldered the new led in between the two copper contacts. only difference is you have to use a 3Kohm resistor on the the positve side of the led. as far as the rest of the switch i just made sure i put it all back together the way it was. Do you still have the parts that came out of the switch? If you do you can send it to me and i'll fix it for you.
i have all the pieces but i couldnt get it to work. i tried to put it back together but didnt really know how since all the pieces fell out, i dont know how they go
the ball bearings sit on top of the metal contacts and the plastic cover has the 2 small springs that should sit on top of the ball bearings.
They are not a direct swap. You have to solder the new LED in place, but first you have to solder the resister to the LED and then to the contact on the switch. Be sure to pay attention to where you place the resistor in reference to the sliding mechanism and the top half of the switch. You'll see what i mean once you open it up. Also, there is no circuit board. Just two copper contacts. Again, you'll see what i mean once you open it up.
MaxLife17
Jun 27, 2019 01:37 PM
The Wizard
24
Oct 1, 2015 08:47 PM
they're working for some people
