Is there a lower final drive?
Old Mar 1, 2004 | 07:14 PM
krismax's Avatar
Father of the 00 VI
Is there a lower final drive we 95-2001 maximas can swap in from nissans ,infiniti,cefiro or god knows what.
I need this badly.
Old Mar 1, 2004 | 08:53 PM
BEJAY1's Avatar
Conecarver
I need this badly.
That's different than just changing the single 5th gear ratio right?
Old Mar 1, 2004 | 10:03 PM
nismology's Avatar
Yes. With a shorter final drive the gear ratios would remain the same. It's just that the maximum speed in each gear would be lower which would prove to be an advantage to people with extended redlines.
Old Mar 1, 2004 | 10:12 PM
nismos14's Avatar
§è~® f®ÈÄk
i'm curious about this too
Old Mar 1, 2004 | 10:29 PM
Jime's Avatar
The only way I know of to do this is with smaller diameter tires. Thats why I run 22x8x15 slicks.
This is the equivalent to going to a 4:35 gear and is one of my best mods.
Old Mar 2, 2004 | 03:31 AM
96sleeper's Avatar
actually there are aftermarket gears for the maxima. Someone posted a website a while ago that I remember had a different final drive I believe. I will try to find it. Tires are the easiest way though.
Old Mar 2, 2004 | 02:58 PM
krismax's Avatar
Father of the 00 VI
Wow that would be great if there is one,a 4:35 to 1 would be sweet and then maybe with the tires the track gear reduction could be around 4:75.
If there is one when i have my new tranny put in with flywheel it will go on too.
Old Mar 2, 2004 | 04:57 PM
stephenlc's Avatar
I think this mod could easily take .2-.3 seconds off the quarter mile for a maxima with all bolt ons.
Old Mar 2, 2004 | 06:06 PM
Nismo87SE's Avatar
I'm alittle unclear on what you want. Do you want a lower numerically final gear like going from stock 3.82 to a 3.62 or do you want lower speeds reached in each gear. Which would be like going from a 3.82 to a 4.17? In any case the 2nd maxima has the same tranny but with a 3.43 final gear, 3rd gens get 3.62 (VE = VQ). A cheap way of getting the gearing you want is to change tire size. In a 5spd running a tire simular to a 205/50-15 is like going to a 4.1-3 final gear. Given the close ratios of the 5spd there isn't much to be gained unless one revs alot higher than stock. The auto's is a different story, basically the higher the final gear number the better the acceleration is.
Old Mar 2, 2004 | 06:25 PM
krismax's Avatar
Father of the 00 VI
I want lower gearing permently,I don't want to ride around every day with low profile tires.
I will be reving from 7500-8000rpm, I think alot of time will be gained from lower gearing.
Old Mar 3, 2004 | 03:31 AM
96sleeper's Avatar
I haven't found that page with the gears yet, but here is an interesting read.
http://forums.maxima.org/showthread....6&page=1&pp=40
Old Mar 3, 2004 | 03:38 AM
Jime's Avatar
The biggest problem the manual trans guys have is traction and that would be multiplied with lower gears. The benefit you are looking at could turn into a negative.
This does help an automatic tremendously because of the higher gearing but I don't think you will actually realize any benefit.
We need a guy who knows all this stuff like Nealoc to jump in here.
dvcamp
Sep 18, 2015 10:17 AM
tcb_02_max
Sep 11, 2015 12:23 PM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
maxinout93
Aug 16, 2015 07:25 PM
