Sx7r Fuel rail off-fitting
Old Mar 18, 2004 | 03:04 PM
Morfeus17's Avatar
Hey!! Any of you guys purchased this fuel rail off-fitting from SX7R. I assume you would need to remove the stock fpr to install the fitting in the fuel rail. But my concern is the fitting itself.. It seems a bit weak... Does this thing require rubber washers or O-rings to keep the seal tight in the fuel rail? Will it leak fuel if I install it as is?? There is no documentation on this, but I wanted to be absolutely sure before installing!!! I dont like to **** around with fuel... Any thoughts or suggestions... Thanks.
Old Mar 18, 2004 | 03:31 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
You re-use your o - ring that sits on the oem fpr and you also reuse the two screws that hold the oem fpr in.
Old Mar 18, 2004 | 04:34 PM
Morfeus17's Avatar
Okay.. That's it?? Thanks for the help...
Old Mar 18, 2004 | 05:49 PM
turbomax97's Avatar
Yeah, tighten your clamps and you'll be fine
Old Mar 19, 2004 | 02:09 AM
teejnut's Avatar
Take your time removing those two little screws. Use the right size phillips and take it easy so you won't thread the screws and you can reuse those screws.
Yeah just use your old O-ring and it'll be fine. Has been for me...
Old Mar 19, 2004 | 06:23 AM
Morfeus17's Avatar
Ok.. Thanks for your help...
Old Mar 20, 2004 | 08:02 AM
WizzaMax's Avatar
i used a locking set of needle nose pliers and lots of patience in addition to the right size phillips screwdriver to assist in getting the screws started coming off so as to ensure i would not strip them out.
Old Mar 20, 2004 | 01:55 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
im still waiting on mine, i dont even know if its in
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
