Is this the IAC Valve???
Old Mar 21, 2004 | 07:15 AM
s0ber's Avatar
I took this thing off yesterday but I didn't really know what to clean, the FAQ said to take off the plastic? What plastic, the female brown connector?? I cleaned whatever I saw and I still have that annoying popcorn sound, i never had it before.. Only when I turned the car off I would hear the ticks...
Old Mar 21, 2004 | 07:22 AM
96white's Avatar
what exactly does the IAC valve do? what are the symtoms when you need to clean it?
Old Mar 21, 2004 | 07:35 AM
s0ber's Avatar
A ticking popcorn like noise, according to most orgers you take out the IAC clean it with TB cleaner and the ticking should go away, I dont think I cleaned it right or understood the instructions correctly...
Old Mar 21, 2004 | 07:43 AM
gtr_rider's Avatar
192.168.1.1
still looks dirty?
Old Mar 21, 2004 | 07:46 AM
96white's Avatar
When do you hear this popcorn like noise?
s0ber's Avatar
NAW! thats the before shots, its all sparkly clean now, well I didn't take off that brown plug if thats what the FAQ meant? Maybe i'll do it again later if someone inputs in here!
Old Mar 21, 2004 | 07:50 AM
s0ber's Avatar
When the cars idling, and when you turn it off...
Old Mar 21, 2004 | 07:51 AM
s0ber's Avatar
Someone told me it was normal just the car cooling off, but I dont remember it doing it while the car was on.
Old Mar 21, 2004 | 11:25 AM
1996blackmax's Avatar
Did your IACV have a gold metal thing that was secured by 3 screws that went into those 3 screw holes? If it did make sure to use locktite on them when you take it apart again, as they do not have washers. I was pretty worried about mine and took off the IACV a few days later just to put the loctite on. I had read a thread or a post about this and how they may get loose and get sucked into the intake manifold.
By the way I did take out that brown thing and sprayed in there with some intake cleaner and I used a rag to clean out the more stubborn stuff. My cars low idle is fixed now .
Old Mar 21, 2004 | 11:40 AM
s0ber's Avatar
Shat, I didn't put no loctite, i'll do it tomorrow just to be on teh safe side... I had a low idle but I changed the fuel filter/pcv valve yesterday along with cleaning the IAC (not the plastic part) and it went away... Im more concerned about this damn ticking noise the car makes... not the injector ticks I mean different ticks that happend every 2 seconds and are random
Old Mar 21, 2004 | 11:49 AM
Hopefully once you clean it out again it will solve your issue. My IACV did have some crud where that brown thing goes into, just take out the 3 screws on the brown thing and it comes right out.
Old Mar 21, 2004 | 12:01 PM
Kevlo911's Avatar
Kevlo for President
I just took that gold cap thing off. I learned that newer 4th gens don't have the cap, but have dimples for hte screw holes.
Old Mar 21, 2004 | 12:05 PM
I had also read that but decided to keep mine on, besides I had already bought the loctite .
s0ber's Avatar
True, i'll probably just take it off too so I dont have to go buy some loctite :P
Old Mar 21, 2004 | 12:51 PM
96white's Avatar
how low was / is your idle?
Old Mar 21, 2004 | 12:53 PM
s0ber's Avatar
It would dip down to 500 sometimes while idling, when i would accelerate in neutral it would dive down to 500 and lift up to like 600... now it dont do that anymore it just stops at about 700
Old Mar 21, 2004 | 12:57 PM
96white's Avatar
hmm, that sounds exactly like what mine does .. can you please send me a link of the write up you saw to fix this problem?
thanks !!
Old Mar 21, 2004 | 12:59 PM
s0ber's Avatar
Well, I did change the PCV VALVE/FUEL FILTER along with clean the IAC VALVE(in teh FAQ) So you might wanna try all 3 if you havn't done the 1st 2 already... I also cleaned my throttle body just to top it off...
Old Mar 21, 2004 | 01:02 PM
96white's Avatar
the only 1 out of that 3 ive done since i bought the car was the fuel filter ( and cleaned tb), so i will try to do the other two to see if it solves the problem.
thanks
Old Mar 22, 2004 | 05:17 AM
s0ber's Avatar
What kind of sparkplugs do you have
TKHanson
Nov 24, 2018 01:39 AM
BkGreen97
Apr 2, 2016 05:47 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
tardrex
Sep 11, 2015 07:35 PM
