Is this the IAC Valve???
I took this thing off yesterday but I didn't really know what to clean, the FAQ said to take off the plastic? What plastic, the female brown connector?? I cleaned whatever I saw and I still have that annoying popcorn sound, i never had it before.. Only when I turned the car off I would hear the ticks...
A ticking popcorn like noise, according to most orgers you take out the IAC clean it with TB cleaner and the ticking should go away, I dont think I cleaned it right or understood the instructions correctly...
When do you hear this popcorn like noise?
Did your IACV have a gold metal thing that was secured by 3 screws that went into those 3 screw holes? If it did make sure to use locktite on them when you take it apart again, as they do not have washers. I was pretty worried about mine and took off the IACV a few days later just to put the loctite on. I had read a thread or a post about this and how they may get loose and get sucked into the intake manifold.
By the way I did take out that brown thing and sprayed in there with some intake cleaner and I used a rag to clean out the more stubborn stuff. My cars low idle is fixed now .
Hopefully once you clean it out again it will solve your issue. My IACV did have some crud where that brown thing goes into, just take out the 3 screws on the brown thing and it comes right out.
I just took that gold cap thing off. I learned that newer 4th gens don't have the cap, but have dimples for hte screw holes.
Well, I did change the PCV VALVE/FUEL FILTER along with clean the IAC VALVE(in teh FAQ) So you might wanna try all 3 if you havn't done the 1st 2 already... I also cleaned my throttle body just to top it off...
TKHanson
11-24-2018 01:39 AM
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
