fpr, fmu and walbro
fpr, fmu and walbro
so what is the exact setup to use the walbro fuel pump (3.33 pulley)
i have the aem fpr and the fuel rail fitting from sx7r and its going in tomorrow nite.
what happens to the fmu?
i just want to know exactly what goes in.
Steve
Steve
Steve
Steve
The fmu receives fuel from the fpr and sends it to the fuel tank, so the order of components is:
fuel pump => filter => fuel rail => fpr => fmu => fuel tank
thanks, thats the type of thing that i wanted to know.
what baseline presssure should i set it at with stock injectors w/ seeing 10 psi of boost?
Set it to oem base fuel pressure, i.e. 34 psi. With the oem fpr, the Walbro (if it is the high pressure pump) gives you about 40 psi.
and the fmu will raise fp based on bp?
Walbro then filter then to fuel rail then fpr then fmu...???
Originally Posted by matty
so for a s/c you need to run a line back into the fuel tank after the FMU ?? Im kind of new at this..
The return line is the fuel hose coming out of the firewall that doesn't have the fuel filter attached to it.
BUMP
does ANYONE have some specific directions for the installation of the fpr?
2. There is a short fuel line from the oem fpr that runs to the metal fuel and vacuum hose manifold thingy under the throttle body. The fuel line is an extremely tight fit on the fpr. I just cut the hose off off.
3. Install the aftermarket fitting into the fuel rail with a new o-ring. I suppose you could re-use the o-ring from the oem fpr, but that is not a good habit to get into.
4. Run a fuel line from the fuel rail fitting to your aftermarket fpr.
5. Run a fuel line from your aftermarket fpr to the fuel return line going to the tank. To do this, you will have to disconnect the return line from the manifold thingy I mentioned earlier. Or just cut it off. You will need a brass 5/16" hose splice that you can get from a hardware store. If you can't find a 5/16" splice, a 3/8" splice will work. I found that the local Ace hardware has a much better selection of brass hardware than Home Depot, if that helps. Splice the return line to the line coming from the fpr.
Chunger
Jul 7, 2002 11:36 AM
CalsonicSE
Mar 14, 2002 12:50 AM
