Noise when I travel over bumps; Help
Old Mar 21, 2004 | 11:11 PM
guido32's Avatar
Over the last few weeks I have noticed an intermittent noise coming from the underside of the car when traveling over bumps. Today, on the interstate with 5 people in the car, the noise was happening all the time (over bumps).
Description: Its a low tone, thumping sound. Sounds like its coming from the rear of the car, but not sure. Sounds like something is loose, and when I go over a bump, it thumps against another piece of metal. I have never replaced the rear shocks, I will be doing that soon. I plan on taking it to a mechanic, but was wondering if anyone had a similar problem/and new what it was.
Old Mar 22, 2004 | 03:22 AM
WillMax95's Avatar
the only thing i can think of is something that happpened to me. when i put my rear speakers in, they bounced around in the back of the deck which made a noise like you are describing. all i did was get some foam stuff from home depot and put it under the deck, never happened again.
Old Mar 22, 2004 | 06:00 AM
kenju4u's Avatar
Please remove the dead body from the trunk of your car. That should take care of the noise.
Old Mar 22, 2004 | 06:45 AM
WillMax95's Avatar
what the hell is the dead body?
Old Mar 22, 2004 | 06:55 AM
RideTheMax's Avatar
The dead person you have hiding in the trunk. You know that girl that's hog tied in the back.
Old Mar 22, 2004 | 07:17 AM
Jepht20's Avatar
Custom User Title...
i have the same noise and haven't been able to figure it out. i replaced my rear shocks, checked my suspension, checked my spare tire, none of the above. really drives me nuts but i do my best to ignore it. i usually hear it more when there's weight in the rear, but still can't put my finger on what's causing it. sounds like a thud...
Old Mar 22, 2004 | 08:24 AM
MaxiMaxima's Avatar
is there junk in your trunk?
check to make sure the jack is secured tightly too.
Old Mar 22, 2004 | 09:57 AM
jamaxin97's Avatar
MadMax in The City
check your exaust. Sometimes it could be one the rear rubber mount bracket that holds up the B pipe might have broken off or the rubber came off. When you hit the bumps, it case the muffler to swing from side to side.
Old Mar 22, 2004 | 10:20 AM
Jepht20's Avatar
forgot to mention that, thanks. i also checked my exhaust many times and still have no idea what the noise is or where it's coming from. i call it my mystery noise.
Old Mar 22, 2004 | 10:42 AM
guido32's Avatar
Thanks guys, I will check my speakers, exhaust, and the items in my trunk. I have heard noises of items moving in my trunk, however, the noise sounds different. I will be sure to check everything. Thanks
BTW: I don't carry around bodies in the trunk. You get caught more easily!
Old Mar 22, 2004 | 11:46 AM
GeeShack's Avatar
Yea, i have the exact same problem. It souinds like it is coming from the shocks and this started happening after i repalced my suspension, with aftermarket springs and shocks. I have uninstalled, and reinstalled the back suspension and the problem still continues. I would love to know how to stop it. It is very annoying.
Old Mar 22, 2004 | 12:15 PM
MadChef's Avatar
on the exhaust hangers (rubber pieces that hold the mid-pipe up), but that would sound more like springs on a mattress.
Worth checking out though.
Old Mar 24, 2004 | 05:05 AM
jamaxin97's Avatar
MadMax in The City
In some cases whenever you install new struts and springs, you have to give it some time to settle in...everything is new and stiff. My car made the same noises (amoungs others that I'm still working on), and after 1000 miles the noise stopped. The only one I'm still trying to figure out, is the sound I'm getting from my front right struts when I turn the wheel...it's sounds like a mild clunk as if the spring is turning. It only happens after I wash the car @ the car wash.
Old Mar 24, 2004 | 06:04 AM
s0ber's Avatar
I had 5 people in the car the other day and my car scraped some big resonotor thing under teh car not sure if thats the b-pipe but it looks like a huge muffler to me... Only on hills and speedbumps...
Old Mar 24, 2004 | 06:34 AM
helloiamphil's Avatar
i had a similar problem, and it was my exhaust...in the middle a lil towards the back, there is a small bar and ur exhaust pipe goes on top of that, sometimes that will tap agaist the bar...maybe thats the problem?
Old Mar 24, 2004 | 06:37 AM
that used to happen to me...whever i took a right turn up any type of incline, there would be a kinda loud clunk...but it just went away after a while...
Old Mar 24, 2004 | 07:27 AM
mymaxlvsattn's Avatar
slackass
maybe your strut bearings?
Old Mar 24, 2004 | 07:35 AM
95Max's Avatar
Just a thought have you checked your e-brake cable. My old car not my Max made a similiar noise and it turned out the e-brake cable was the issue....worth a check.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
