at and powersteering fluids
my car has 80k miles on it. i took it to the dealer today to have it looked it (inspection). they said my brakes needed work done, fuel injectors needed to be cleaned, AT and powersteering fluid needs to be flushed and replaced and my drive belts are nearly worn out. total cost came to $800. i only had the brakes and belts fixed ($300). how serious are the fluids? can i get that fixed at autozone? Thanks
You can drain the tranny fluid and fill through the drain plug and refil. If you want to go one more, drop the pan and clean (instal a new gasket) and fill.
For the PS use a turkey baster and drain the PS jug and refil with fresh fluid. I do this on a regular basis.
This can same you $$ over the years, good luck.
the flushes will cost me a total of $250. they are also going to do a "fuel induction service" on the car. will the bg44k accomplish the samething?
Originally Posted by sloppymax
the fuel cleaning they do may go a step further but you will not a difference between that and the bg. a tranny drain and refill is very easy to do since there is no filter to change. if you do not have the time or desire then the dealer can do a drain and refill too but they will always push the flush since it has more profit but its your call. at 80k, if it has not been done then i would get it flushed. as for the ps, you can use the turkey baster method but my problem is that i cannot find a baster small enough. skip the fuel system service and just buy the bg or chevron.
Thanks alot. I think Pepboys will flush it for me. I had my work done at Superior Nissan on south boulevard in charlotte. you familiar with them?
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
