Install instructions for brake pads?
Old Mar 31, 2004 | 08:11 PM
jykishan's Avatar
is there a writeup for changing out your front brake pads that anyone knows of? and btw this link in the HOW/TO section is a dead link http://boostedmaximas.com/howto/brakepad.html
Old Apr 1, 2004 | 12:25 PM
jykishan's Avatar
anyone ......?
Old Apr 1, 2004 | 01:05 PM
schernov's Avatar
http://motorvate.ca/mvp.php/300
Old Apr 1, 2004 | 02:02 PM
Uconn411's Avatar
Brake Install Notes:
Front:
1. Remove the bolts holding the upper piece of the caliper on...14mm...these came off without any effort...slide the caliper off and hang it on the coil of the spring.
2. Remove the brake pads...they pop right off...pay attention to the way they are seated.
3. Remove bolts holding the lower piece of the caliper on...19mm...these require some elbow grease to remove, but I did not need any liquid wrench or a breaker bar...slide the second caliper piece off and set aside.
4. Remove the rotor...requires some rocking and tapping to remove...my stock rotors did NOT have a bolt hole easy removal so I did some light tapping on the back side with a mallet as I turned the rotor.
5. Install new rotor...clean up the wheel hub first and rub some grease around the hub to prevent the new rotor from rusting onto the hub like the stock one.
6. Reinstall lower piece of caliper...clean it up first to remove all the brake dust...tighten up 19mm bolts good and tight.
7. Install new brake pads...ensure that you remove the backing plates off the old pads and install them to the new pads.
8. Compress the piston on the upper piece of the caliper...loosen cap on the brake fluid resevoir by the driver's side strut tower in the engine bay to make piston compression possible...use a clamp and equally distribute pressure as you compress...watch for brake fluid overflow.
9. Reinstall upper piece of the caliper...clean it up first to remove all the brake dust...tighten up the 14mm bolts marginally (remember how easy they were to remove).
You're all done. Differences for the rears:
• You must remove the 14mm bolt holding the mount for the emergency brake cable to get the upper part of the caliper off...underneath the caliper.
• Lower piece of caliper is held on by 17mm bolts instead of the 19mm on the front.
• Piston needs to be turned clockwise to be compressed...I suppose you could use pliers, but you can buy a small piston compression tool which hooks on to a ratchet and makes life really easy...the one they sell at Sears has a piston pattern which fits the rear calipers on the Maxima.
• Make sure you hook the emergency brake cable onto the spring mechanism before reinstalling the upper caliper piece as it will be hard to hook back on after the caliper is assembled.
Old Apr 1, 2004 | 02:17 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Check the 4th gen forum How-To sticky. All kinds of jewels in there.
What pads are you using?
I'm going with Hawk HPS, slotted rotors, SS lines, and UNKNOWN fluid flush. Probably Motul 5.1, Super Blue ATE, or if I wait too long Castrol syn..
Old Apr 1, 2004 | 05:42 PM
jykishan's Avatar
i have in there rite now axxis pads, they've only been in there for a year and theres really bad grinding happening for the last couple weeks , i'm gonna put in hawk pads this time around in the front
Old Apr 1, 2004 | 08:46 PM
IceY2K1's Avatar
Yeah, Axis MM dust too much for me.
Hawk HPS and next time Raybestos QS unless I love the Hawks.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
