Will a CAI F up my Engine?
I used to own a 96 cavalier. I droped an Intake on it and 1 month later it started to over heat. I had to replace the dam piston heads. I now have a 99 Maxima SE-L. I love my max. I don't wana f it up by installing aN intake. So, can anyone tell me if intake is good for the car and won't kill it. I am thinking of buying an Injen CAI. What are ur thoughts?
My 97 Max had a midpipe and cone filter for 2 years with NO problems and my 2001 has had a PR CAI on it for a few weeks now. You should have no problems with any intake as long as its a good one, berk, Place Racing or Injen with a good filter (K&N or Apex'i)
HAHAHA -- yes!!! an injen will f-up your car and that's why so many people on the board have them! (including me)
many cheapa$$ american cars suck esp cavaliers slow and ugly POS -- that's why you have a maxima
the only way you can f-up your max is if you have a 2000 (which you don't) with a CAI and then your MAF blows because nissan didn't use the right MAF the first time, but that's a diff issue that doesn't affect you.
bottom line go get an injen. and read the FAQs before you post something like this again.
Yes a CAI can **** up your engine, don't matter what kind of car you drive. If the thing sucks water, you will hydrolock your engine.
I have seen a few cases of these in the past years, so just be careful and don't drive through some deep puddles.
Originally Posted by Krash513
It makes sense that you can mess up your car with a CAI, but in order to do that youd have to partially or completely submerge the filter. Youd basically have to drive through something 12" deep or more.........
which means. That It can be done.... and has happend before
for the record AEM bypass valve works like a charm it was tested in some 2002 issue of Sport Compact Car on AEM's owner's NSX! at full throttle the filter was submerged in an aquarium of about 10 gallons of water.
the water went up for about 6 inches (at full throttle) then the bypass valve quickly opened, the water immediately came down, and air was sucked through the bypass valve.
i never had any problems with injen. (it uses a K&N oiled filter) and the only reason it might possible suck in water is if you have no undercar shields AND you drive into a 2ft deep puddle of water or off a short pier.
You get what you pay for, I have seen some intakes that will probally cause damage. I would stay away from intakes with foam filters. I have pulled an intake off before and found foam on the inside of the the intake and on the plate of the throttle body. Foam can and will break down under heat. It is very unlikely that foam will screw up your internals because it will pretty much burn up before it does any damage. However, it is very possible for it to damage you MAF. So I personally would stay away. There are many quality intakes for the Max though.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
A32goldylocks
Sep 16, 2015 01:33 PM
