Punched Out Catalatic Converter
Old Apr 3, 2004 | 05:26 AM
JHILSMAN1's Avatar
Well, I Punched Out The Cat In My 2000 Se And Have Had The Ses Light Ever Since. It Seems The O2 Sensor Doesn't Like It. Does Anyone Know If There Are Any Simulators To Fix This Problem Or Have A Cheap Stock Cat For Sale. Right Now I Have A Straight Racing Pipe On It With The Same Problem. Please Any Help Will Be Appreciated.
Old Apr 3, 2004 | 08:20 AM
Zero Deuce SE's Avatar
It's revenge of the cat. J/k. I belive that it is illegal to sell a used cat unless it has been tested. You might end up buying a new one. Ouch!
Old Apr 3, 2004 | 01:39 PM
Weimar Ben's Avatar
Helicopters! Money!!!
sounds like you have a cali spec model. Get an aftermarket free-flowing cat. The magnaflow one looks nice.
Old Apr 3, 2004 | 07:02 PM
JHILSMAN1's Avatar
NO, ITS FED SPEC. I AM NOT SURE IF A HIGH FLOW CAT WOULD HELP, MIGHT HAVE THE SAME PROBLEM...ANY OTHER IDEAS??
Old Apr 3, 2004 | 07:04 PM
JHILSMAN1's Avatar
WELL, A NEW CAT RUNS ABOUT 700-800 DOLLARS ACCORDING TO THE DEALER. THANKS ANYWAY.
Old Apr 3, 2004 | 07:20 PM
Weimar Ben's Avatar
Try turning the CAPS LOCK key off.
If you don't have any O2 sensors after the cat, I don't see how punching out a cat or putting in a test pipe would throw a code. If you have a O2 sensor after the cat, then I would see how it would throw a code since there is some residual fuel in the exhaust for the cat to use.
Don't buy a cat from the Stealer. There's a Magnaflow cat on ebay for $58.
Old Apr 3, 2004 | 08:31 PM
SoonerFan's Avatar
Cletus
i have FED spec and have a sensor right after the cat. ive been thinking about the punchout but was worried.
talked to my buddy at the service dept today about it and "the light will come on, but that is it. ecu WILL NOT CHANGE fuel/air mixture like a bad front sensor will. unplug the battery and the light will go off and store the code"
Old Apr 4, 2004 | 06:03 AM
No worries. Check this price out.
http://www.trademotion.com/partlocat...=9&catalogid=2
Old Apr 5, 2004 | 01:57 PM
JHILSMAN1's Avatar
Thanks for your help.
Old Apr 5, 2004 | 02:05 PM
Driven EF9's Avatar
Why?
Oh, that's why you wanted it punched out...
how about a non-punched out cat?
gutting the cat does wonders for turbo cars... hardly any gain with NA.
just don't punch out the new cat you get.
you could also go to midas, see if they'll weld one on for ya (ask them to weld it to your stock brackets)
Old Apr 5, 2004 | 02:12 PM
You're welcome, anytime.
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
ivorton23
Sep 28, 2015 09:08 PM
lrb6805
Sep 18, 2015 07:07 PM
carid
Sep 9, 2015 05:06 AM
