Injen Clone intake installed-----this sucks...whats up(pics)
Im not sure if this is normal, but i installed the intake and now my car runs like ****. It seems like the low end is GONE. Do you guys think I installed it wrong or what? I installed a larger better filter than is in these pics.
thanks peoples
thanks peoples
Originally Posted by Tyrexx
did you used to have hai? you definatly shouldnt feel power loss.
when i stomp the pedal it hesitates or bogs before the rpms go up and it makes any power.
Originally Posted by maxima1998gxe
just installed my injen last night and didnt notice any power loss. it sounds and runs better too. not to mention the old butt dyno felt the extra power
Cold air intake really arnt made to race people from a dead stop they make the most horse power above 3500 rpms so if you race someone make sure your going about 25 to 30 mph before you mash on the gas. I got mine to pass slow old people on the highway
CAIs are supposedly better for low end power even though I think they're better all around.
I looked at your home page and it appears that your MAF sensor is plugged in as well as your vaccume lines.
Question, did you plug the very small vaccume line that was connected to the bottom of your resonator (the think black box between your MAF and throttle body) into the intake?
did you poke out your maf screen to "gain" hp? how does it rev in N? boggy at all? have you checked for leaks? examine the filter....maybe it some how is covered in crap. did you take the plastic off it?
Originally Posted by drjohnnyfever
I went from all stock intake, and now feels like i dont have any pull at all.
if you want better throttle response, swap it to short ram. for the best throttle response, go with popcharger setup.
i have the same intake and i felt some pretty impressive gains. check your codes there must be something wrong. double and tripple check to see if you pluged everything back up. u might also want to clean your TB if you didnt do so already(that alone should help out alot)
yeah......after driving it for awhile, I think im driving a little dif then b4 to compensate for the loss of throttle response. Even though I think im starting to notice the mid range gains i miss that snappy trottle response that im used to getting. So whats the solution? MEVI? One of my friends also mentioned using an adjustable fuel pressure regulator to increase the fuel pressure at low rpms, whats the deal with that?
I took the Injen out of my car in just 1 month. Low end was completely gone, especially in the hot summer months.
The best intake for our cars is a slightly modified stock setup. You keep your low end, throttle response and if you just open it up slightly, you gain at the top end as well. This is true for all N/A VQ's.
Pop chargers lose low end.
Injen is by far the worst.
A true CAI suffers at the top end, not enough volume of air gets in.
The stock intake flows very well, just provide an additional path for air into the system just after the most restrictive part, which is the snorkle.
happyricefob, i put a HAI on my car and lost loads of low end. what's worse is that i don't think i gained anything in the mid to high end. i'm actually pretty disappointed in it besides the great sound. can't go back to stock either since i drilled a hole in that box in between the maf and the TB for the IAT sensor.
[IMG]http://images.cardomain.com/member_images/6/web/330000-330999/330843_15.jpg
[/IMG]http://images.cardomain.com/member_images/6/web/330000-330999/330843_16.jpg
thanks peoples
thanks peoples
-Terry
injen in my opinion gives us the best gain at mid range, and thats where i wanted the most power gain, i'm very happy with it, i have no problem spinning my tires off the line, of course, i am a 5 speed so that helps out a bit. i dont think injen is the worst, maybe for you auto guys it is, but i love my injen knock off. for the most part intakes provide some hp over the stock intake, but the stock intake incorporates the best means for driveability, with the injen u want to keep in the mid rpm range for best driveability.
LOL!
I always laugh at peeps debating the CAI, HAI, and Hybrid setups.....
Best thing for the Max without a MEVI is a Hacked airbox.
I tested out the stock box, the CAI and the Hacked airbox. I felt the best responses from the Hacked Airbox. Great stop launches, plenty of passing power when i want it.
easiest thing i can say to do is to sell that CAI on ebay, and then take a look at my webpage and look at how to hack an airbox. Just click the www button below this post.
Also, once you try how i did it, you can hack it futher like i have mine now by cutting away everthing but the bolt mounting holes and plastic to connect it to the lip that holds the top part of the box and filter together. I also left the side with the cold air scoop entrance. This way, i get some cold air, and some heat reflection. So i get cold air at faster speeds which helps high end, and hot air at rest which helps low end torque.
turbo or mevi with CAI is only time i would use.
2¢
2¢
Originally Posted by luckee2bhere
WOW...maybe you should never try to do anything to your car ever again.
how do you mess up an intake?
Originally Posted by ImStockBaby
I have the exact intake as you... Tonight I tried somethin different by taking off the bottom pipe and attaching the filter element right after the MAF, now it sits behind the cooling fan. I also have the cooling fan mod, I went for a test drive, leaving the fans on, and honestly it feels 10x better than with the extra piping.. WAY BETTER.. give it a try. I will try to get some pics of what i'm talking about tomorrow.
-Terry
-Terry
got a pic of that yet?
i did that too. only problem i found is the filter is 3 inches from the engine. aka hot air. i find stock is the best.
blah blah
its just a damn intake.
the only reason we have them is for sound.
if anyone thinks otherwise your silly and wrong and fooling yourself.
an aftermarket air intake never made a difference in any 1/4 mile run i know of.
blah blah
blah blah
blah blah
FINALLY SOME F*CKING HONESTY ON THIS FORUM
Originally Posted by LastBoyScout
LOL!
2¢
2¢
Hey wheres your picture of your hacked airbox. I am interested.
Dude I know exactly what you are talking about. After I installed my intake some times my car would just freak out and have no power. It ran like complete ****. I would let it sit for a while and it would stop. It did that for like a month but than it just stoped doing it. It was weird. I posted about this but nobody else had ever seemed to have the same problem. I checked and double checked, and checked agin. I had everything installed the same as I do now and my car runs fine now. It just freaked for a while. Hope this help
With all of the dynos I've seen on the org with CAI's, its been proven that they have that terrible drop in power above 5500 rpms. The hybrids hold a better power curve but you also lose a little low end.
I got rid of my hybrid setup and went back to the stock resonator with the Apexi filter. It's been proven that resonators are good for making low end power on NA engines.
hayne
Oct 5, 2015 11:53 AM
Mahmuth
Sep 17, 2015 11:45 AM
