fuel filter
Old Apr 7, 2004 | 03:11 PM
sk24iam's Avatar
fuel filter
I can't seem to get the screws to budge. Tried every screw driver I own. What next?
Old Apr 7, 2004 | 03:14 PM
SkinnyMax's Avatar
maxima no more
well if you can't get the hose clamps off, then your only option would be to cut the hoses and put some new clamps on there. be careful because there isn't much slack to begin with so cutting off 1/2" from each tube will make it more difficult to work down there.
Old Apr 7, 2004 | 03:22 PM
mclarke's Avatar
use some PB blaster, let it soak in 5 mins, hit it with some more, then let that soak in for 10 mins or so, hopefully will loosen it up for ya
Old Apr 7, 2004 | 05:47 PM
ny96max's Avatar
just as a warning there is pressure built up in the lines goin in and out of the filter, and by you cutting these will cause lots of gas to shoot all over and make a nasty mess. I suggest you get something to pentrate the screws and do it that way.
Also if you check the FAQ's there is a post on how to properly change your fuel filter out.
Ant
Old Apr 7, 2004 | 06:04 PM
waveridr85's Avatar
the screws are also bolds, use a socket wrench on those and they will unscrew in a snap. Oh yea, check the for sale section on LIMaximas.com
Old Apr 7, 2004 | 06:32 PM
hotshtsr20's Avatar
chances are the rubber hoses wont come off either. take a pair of pliers and clamp the hose LIGHTLY over where the hoseclamps are (before you loosened them) and twist the hose. this should break it loose so that they will come off relatively easily.
Old Apr 7, 2004 | 09:40 PM
Daniel's Avatar
i just changed mine today and it came off pretty easie, it took me about 1/2 hour
Old Apr 8, 2004 | 07:36 AM
twiggy144's Avatar
removing the air filter box will give more room to work around the fuel filter
Old Apr 8, 2004 | 07:56 AM
Brudaddy's Avatar
is it necessary to remove the air filter box though? I am probably going to be doing this Saturday.
Old Apr 8, 2004 | 10:36 AM
sk24iam's Avatar
I'll try this stuff, such a pain, in such an bad spot.
Old Apr 8, 2004 | 10:47 AM
twiggy144's Avatar
No. But it helps a lot. Unless you have 2 elbows in your arms.
Only takes 10 minutes. A well invested 10 minutes. Easier than it looks. Start by removing the filter box top, the filter, and the retaining screws and wires to be removed and disconnected will all be in sight.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
