Please please help.. RSB install !!!
1. Is it a stillen RSB or a Progress/Addco/Cattman setup?
2. IF it's a stillen, you probably pinched the rear brake line/abs line that runs on the control arm.
3. IF it's a stillen, sounds like it is not far enough back, OR you have it upside-down.
4. IF it's not a Stillen, I can't help
Originally Posted by scopium
yea it is stillen.
so i need to move it a nothc backwards?
and i looke and i did pinch one of the brake lines.. i fixed it by " depinching it" but the light is still one..
what else can i do
what else can i do
If it was the ABS sensor cable, you may have broke it and it may be detected by the ECU as a damaged sensor. I'm not sure but you may have to replace the whole sensor...
Check this
/Mods/Handling/StillenRSB/BracketsLeftSide.jpg)
The black hose closer to the right upper corner is the brake line. The cable close to the Stillen brackets is the ABS sensor cable.
If it's banging then check the passenger side bracket that goes in the middle of the sway bar. It is hitting on the rear suspension yoke. The yoke is offset and mounted more on the passenger side than the driver's side. Just get under the car and look carfully, you'll see the area where it's all banged up.
yea but i dont have a bracket in the "middle of the sway bar"
i got stillen.. just four brackets on the sides..
and can anyone tell me what holes i should put the brackets on... and where exactly i should put on the brackets.. i think my brackets are too far apart..
called nissan .. i have to pay 340 dollars to have my ABS sensor replaced....
Oh boy, that hurts!! Sorry about that. About the noise, you may want to check the clearance between the sway bar and the beam axle. Mine has like a 1/4 inch and I can hear it banging the axle in some occassions. Loose the nuts 'n' bolts for the brackets a bit and move them a bit towards the front of the car, to create some clearance between the bar and the beam axle.It should look something like this
/Mods/Handling/StillenRSB/RSBInstalled.jpg)
By the way, these pictures are from www.greghome.com, the web page of one of the .org members. He has a step-by-step how-to for installing the Stillen sway bar.
Good luck.
yea i squished the ABS hose.. i guess i have to replace it..but i heard from a couple of people its not a mojor threat..
no worries.. today i went to the dealer after taking off the sway bar.. asked if they could fix my ABS under warranty.. at first they said no.. but after a bit of loud talking and causing a scene they offered me the part for free.. but asked for labor.. i just took the part can changed itmy self.. everything is fine now.. just need to put the sway bar back in place without any bangging
thanks again to all the people that helped me throught this situation
thatcollegestudent
18
Oct 5, 2015 02:29 PM
