Ebay Exedy clutch kit
I am in need of a new clutch, I was planning on getting the OEM
from nissan (not key value), but then I saw this on Ebay. Does
anyone have any experience with this kit? and is it OEM,
equivilant to OEM, or is it like the key value kit? I know
that it's not the stage 1 performance clutch. All I need is
equivilant to the OEM, I don't want to end up with something
like the key value kit.
Thanks, heres the page:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33730
I bought the exedy clutch kit off ebay... only from iclutches. Although I'm in the break-in phase, I can say it feels and behaves like the stock clutch. It'll be another 250 or so miles before I flog the thing though.
Yeah. Just wanted something at least as good as stock. The Exedy replacement is supposedly 10% better clamping force. To me, it just feels at least as good as stock, including the pedal feel. No noises going into gear and no apparent chatter. You really can't tell the upper limit of performance until you shift aggressively though so I can't really give the full thumbs up just yet. I did adjust the pedal clutch takeup to be closer to the floor though but I don't think that had anything to do with the clutch.
iclutches was a great vendor. Sent tracking info and the package went out the next day. Seller even sent a thank you after I left feedback. Seemed pretty conscientious.
mish..how do u adjust the clutch to catch closer to the floor..that little screw above the pedal? mine catches at about 1 or 1.5 inches from the upper limit.i dont like it..
im still breaking in the exedy stock replacement. i agree with everything mish says.. catches like the stock, feels like the stock, no noise, grinds. havnt smelled burnt clutch yet when i get out of the car. so far so good. ill mash mine in 400miles to see how well it holds the topend.
thansk mish..ill try that soon..does the clutch rod leads into the nut?i will know what it is when i look at it right..
i took a look at the assembly..im pretty sure i see the clutch rod.. its threaded and kinda serrated..and goes intothe wirewall.. its not where the pedal lever is with the black button is.
i tried taking off the but, its a 12mm i thin..but cant get it off..i move the wholething the nut is connected to..is it easy to turn the clutch rod.. i can get any kinda leverage in there..no space.
You have to get a pair of pliers to turn it. It will only turn once the nut is loosened. A needle nosed pliers did not work for me. Try a fatter one with good teeth. Like I said, there is only room enough to turn it a little at a time. Kind of frustating because of the position.
yeah.i finally got it to turn..omg.its very very frustrating.. the catch point is a little less than halfway now..(closer to the floor). i think that is a good catch spot..lots of distance both ways for clutch to fully engage and disengage..thanks mish.
t6378tp
Sep 29, 2018 04:27 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
pears
Sep 18, 2015 05:25 AM
