RE: fog light rewire
I got the instructions on how to rewire my fogs, but the only thing that is missing was which light to tap into at the headlamp. Does anyone know? Is it the clearance light or the blinker light? It would be for an 02 max. Thanks!
Here is the fog light rewire Link
http://www.max-world.org/writeups/5t...fogrewire.html
Here's the one I used for my wiring:
http://www.innerbean.com/housecor/fog_rewire.html
An excellent writeup IMO.
Originally Posted by s_hinerman
It might be a good answer. It might also render you foglight switch inoperable(if that matters)
I emailed him to check and will let you guys know
And yes, this is easier than the other technique. No need to run a wire to the headlight.
Oh, and I just responded to your email with the same answer.
Thanks for the help!! Since we are on the topic of lights, Just 2 days ago one of the headlight housings started collecting moisture inside it......alot of moisture! I was hoping it would dry up after a few days but it hasn't, and ofcourse I just went over on miles for factory to take care of it. Anyone have any How To's to get rid of the moisture?
Originally Posted by housecor
Check out the DDE Lightning install how-to on my site to see how to heat the lights in the oven. This will soften the seal. Then, use channel locks all the way around the light to make sure the plastic lens is sealed tight to the black housing.
Just got to read this tonight. Thanks Housecor!
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
