Help - Sunroof only opens/closes a couple of inches at a time??
I have searched but found nothing re: this problem. Anyone experience the sunroof only opening or closing only 2-3 inches at a time. Do I need a new motor or is there a known fix. Any help would be greatly appreciated.
Originally Posted by Vadim
have you recently unplugged the battery? there is a reset procedure for a sunroof, I believe you have to hold either tilt up or down button for a couple of seconds. It is also in a car manual
Originally Posted by Nyc2kMax
yeh what u got to do is unplugged the battery. I happen to me when i first brought the car
Originally Posted by PhillyFanCS
That's it?? Just disconnect and reconnect battery?? Does it need to be disconnected for a certain amount of time??
1)Hold the close tilt button down for 20 seconds. This resets the sunroof (you'll here a click).
2)Unplug the relay under the steering wheel.
Neither one helped my problem with the sunroof. Finally I took it to the dealer and they updated the software. Sunroof works flawlessly now.
Originally Posted by maximillus
it could be your fuse
None of the above mentioned suggestions worked but thanks for the input.
If it was the fuse wouldn't it not work at all?? When I close and or open it moves a couple of inches and then there is a click at the switch.???
I do remember hearing of issues like yours and a motor/pc board assembly needed to be replaced, but I am not 100% if that will be your solution.
Originally Posted by Colonel
Guys, he has a 00. Its a MECHANICAL sunroof so all the reset suggestions dont apply here...that process only applies to 02+'s.
Sounds like I was trying fixes which don't apply to my year, anyway..... I will see what the dealer has to say but I think pushing the switch 5 times to open or close is a pretty cheap alternative. Also the sunroof is a little unlevel and I have heard there are shims which can be put in to level.?? Any info on that??
BobMax
Aug 21, 2015 07:38 AM
BobMax
Aug 15, 2015 12:35 PM
altome15
Aug 10, 2015 07:05 PM
yat70458
Aug 3, 2015 01:16 PM
