exhaust question
Old Apr 28, 2004 | 05:19 PM
ajsince81's Avatar
exhaust question
i have a 2002 with stillen intake, b-pipe and a 75 shot. Would a y-pipe and straight pipe make a difference? any other suggestions? i would like headers but they are a little out of budget right now. how about changing my intake to an injen CAI? is it worth it?
Old Apr 28, 2004 | 07:39 PM
MaxSpeedSE's Avatar
Id like to know the same...
-Chris
Old Apr 29, 2004 | 12:23 AM
CalsonicSE's Avatar
Definitely get the Y-pipe. N/A, it adds ~15hp. It's even more beneficial when spraying (or boosting).
Old Apr 29, 2004 | 02:09 AM
Jime's Avatar
They Y-Pipe may add ~15 HP on a 4th Gen but not on a 2k2, the result is very minimal because you are not removing the precats like the 4th Gen Y-Pipe and headers do.
You can get HS Headers for approx $550 which includes the Y-Pipe and the gains are ~20 HP and highly recommended. As far as the rest of the system, the pipe when nearing the muffler is down to less than 2" and is a real bottleneck when running spray.
So, I would recommend the headers, straight pipe and b-pipe as well as replacing the pipe from the end of the B to the muffler. What muffler you use is a personal choice.
I have a Budget straight and B-Pipe. You can get it with or without resonator and its flanged so it can be removed very easily and replaced with just a straight pipe if you want, later on. I have both and without the resonator its pretty hondaish.
Old Apr 29, 2004 | 04:18 PM
ajsince81's Avatar
thanks Jime, does the headers make a big difference in sound. I'm keeping the stock muffer so the exhaust looks and sounds close to stock, but a nice exhaust tone would be fine. Jime if you don't mine me asking, what did you do to your 2k2 to run 13.5 all motor?
Old Apr 29, 2004 | 05:13 PM
waveridr85's Avatar
hey, i have a 2.5 presure bent bpipe, would i gain much of a difference going to mandrel bent?
Old Apr 29, 2004 | 06:22 PM
Jime's Avatar
I do hear the engine noise a bit but not much and it really barks when you start it, other than that I really can't tell any difference.
All my mods are posted here and I don't do anything magic it can all be repeated by anyone.
https://maxima.org/forums/showthread...=305469&page=1
Old May 10, 2004 | 01:06 PM
ajsince81's Avatar
Do i need the single output or dual output o2 simulators on my 2002 3.5L, when I install the headers
Old May 10, 2004 | 01:20 PM
Jime's Avatar
You definately need the duel output because you 2 primary which remain and 2 secondary which you need the simulator for.
You can just extend and install the stock o2 sensors after the cat if you have one, I don't thats why I use the simulator.
Old May 10, 2004 | 01:46 PM
ajsince81's Avatar
I have my main cat right now, I might switch to a straight pipe later. Is it easier to extend the stock o2s or get the simulator? Is one better than the other?
Old May 10, 2004 | 02:11 PM
Jime's Avatar
The rear o2's don't really have any function other than to tell the computer if the cat is working or not.
Installing the simulator is easier than welding in 2 bungs behind the cat and extending the o2 sensors, imho. If you are going to a straight pipe later definately do not extend the stock ones its a waste of time and money.
Old May 10, 2004 | 02:17 PM
ajsince81's Avatar
Thanks Jime for all the help. This my be i stupid question, but to make sure I only need 1 dual output simulator right and hook both secondary o2s it?
Old May 10, 2004 | 02:56 PM
Jime's Avatar
You got it.
I did a lot of reading and asking too, so no problem.
Old May 10, 2004 | 05:14 PM
MaxSpeedSE's Avatar
Jime is it worth switch from a warm air intake to cold if on n2o? are the gains worth it?
Old May 10, 2004 | 05:20 PM
Jime's Avatar
Not really sure, I haven't compared a lot.
However, what I do now is run a wai on the street and then pull the headlight at the track and run a velocity stack in the light opening. However you either have to have a small battery or relocate to do that.
I am just about finished my own creation for an intake and will post a pic when I get done.
Old May 15, 2004 | 01:16 PM
ajsince81's Avatar
Jime I order my hotshot headers yesterday, I done most the work on my car myself, I seem to be able to figure things out fairly easy. Is the install for the headers something i should try myself? Any advise?
Old May 15, 2004 | 01:32 PM
Jime's Avatar
Well its not a complex job, I did mine all by myself. However, the location of the header nuts make it very difficult to remove them and I had to buy a couple of extra sockets, crowsfeet, swivels etc. I think I used a different almost for each nut. You also have to remove the intake which is not a big job and is necessary even for plug changes.
Its rewarding when you get it done and save yourself 3 or $400 in labour. Give yourself lots of time ie a couple of days in case you run into a bit of trouble removing some of the nuts etc.
Old May 16, 2004 | 01:32 PM
ajsince81's Avatar
thanks Jime again!
Old Jun 23, 2004 | 07:03 PM
Muravchik's Avatar
Is a 3" exhaust going to help in any way while spraying? And if it does, how bad is it for NA driving?
thanx
Old Jun 23, 2004 | 08:54 PM
SonicDust187's Avatar
3" will help, but will make NA driving worst since you will loose a lot of low end.
Old Jun 24, 2004 | 06:33 AM
MaxSpeedSE's Avatar
i love my 3 inch exhuast =)
Old Dec 24, 2004 | 08:49 AM
JeEvE's Avatar
A 3" exhaust will actually help over 2.5" when spraying? Im running stock exhaust with a 50 shot, is the exhaust a major bottle neck or am I loosing only a few hp?
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
