Grainy vibration thru the clutch, shifter, and gas pedal
Old May 10, 2004 | 12:25 PM
Dave B's Avatar
Not DAVEB the parts guy
Does anyone else experience a slight grainy vibration thru clutch, shifter, and accelerator pedal? Don't get me wrong, it's not extreme, it's just noticable enough to be a little annyoing. My car has been doing this for at least 2 years if not longer. Also, when I push in the clutch to shift a gear you can feel a very mild vibration thru the clutch. The passengers don't feel jack, just me because I'm using components connected to the tranny and motor. In neutral when I rev up and can't feel a thing nor thru the steering. The graininess seems to be more apparent under load. My front and rear mounts are new and the side mounts are fine.
I'm beginning to think the problem could possibly be a scored flywheel. My car has the stock clutch, 107K miles, and over 150 1/4 mile passes. While the clutch has never slipped, I can only assume everything has taken a big beating. For the past 6 months I've been able to hear the pressure plate fingers making a popping sounds when I press in the clutch.
Dave
Old May 10, 2004 | 12:44 PM
Jeff92se's Avatar
I'm needing a caw
Possibly the T/O bearing. I assume it's taken it's fair amount of abuse. If the bearing is shot or if it has ejected all it's grease, it might make a grainy sound when you press the clutch
Old May 10, 2004 | 01:15 PM
nismos14's Avatar
§è~® f®ÈÄk
by grainy do u mean sorta roughish? it just doesnt feel smooth?
Old May 10, 2004 | 05:00 PM
Dave B's Avatar
Basically.
Dave
Old May 10, 2004 | 05:34 PM
nismos14's Avatar
§è~® f®ÈÄk
i've got that, however i think its because my fly wasn't resurfaced when a new clutch was installed
Old May 10, 2004 | 06:24 PM
matty's Avatar
I have that with a Fidanza Lightweight ??
matt
Old May 11, 2004 | 02:12 AM
sryth's Avatar
I have it too...it's a recent development with my car, though.
I notice it on the gas pedal when the clutch is engaged, so that rules out the TO bearing as the cluprit (in my case, anyway).
I've suspected my wheel bearings of being faulty; maybe that's my problem. Does this only occur when you guys are moving?
Fbana41
Aug 29, 2016 12:18 PM
Lilfatz301
Sep 18, 2015 08:06 AM
Maxxx10
Sep 13, 2015 03:16 PM
slowlifer
Sep 8, 2015 05:53 AM
