Manually wire fans - link please
Old May 13, 2004 | 05:10 AM
waveridr85's Avatar
Does someone have the link to how to manually wire the fans for track use. Jime did the writeup but i can't find it. Thanks
Old May 13, 2004 | 05:47 AM
Zero-K's Avatar
VQ30DET
Here ya go, its in the 4th Gen How To's
http://forums.maxima.org/showthread.php?threadid=129181
Old May 13, 2004 | 05:50 AM
Jime's Avatar
For the 4th Gen.
Actually I have a much simplier and easier way now. You just have to tee into 2 wires to the ecu, one is for low and one for high, I just use the high one.
The pins you must ground for the 4th Gen are 14 and 13. Lo=14, Hi=13.
This is the pic for the 2k2 which is the same except the pins.
These are just signal wires so any light wire will do, all the ecu does is ground out those wires when Hi or Lo speed fans are called for.
Old May 13, 2004 | 06:10 AM
waveridr85's Avatar
so all i need to do is ground them to something? when you say tee, that means just plice into?
Old May 13, 2004 | 06:18 AM
Jime's Avatar
Yes to all.
Old May 14, 2004 | 04:15 AM
Zero-K's Avatar
VQ30DET
awsome Jime, thats easier than the old way.
Thanks for finding that.
I'll have to switch my current setup, so I can slowly get rid of some wire cluster in the engine bay
The Frye
Sep 2, 2021 11:03 AM
pjgreek
Sep 9, 2015 09:30 PM
minsbang
Sep 5, 2015 05:36 AM
