fill er up (i think)
Old May 14, 2004 | 11:14 AM
MerkMax's Avatar
I have a 91 se, sometimes when I go to fill the gas tank the gas pump will keep clicking off like the tang is full, but I know it is empty. I can't imagine what would make this happen. If this has happened to anyone else please let me know.
Old May 14, 2004 | 11:50 AM
Bill Brasky's Avatar
Seperated at Birth?
you're putting the diesel nozzle in... try the gas one next time. i hear that works.
Old May 14, 2004 | 03:58 PM
medic's Avatar
you're probably not making the seal correctly with the nozzle.
the other option is that your fuel tank filler neck is pinched - in that case the gas isn't flowing into the tank fast enough backing up and making the nozzle think your tank is full.
Old May 14, 2004 | 04:14 PM
CandiMan's Avatar
Say Candyman 5 times
After the pump pops off how do you know it's still empty
Does the gas needle varify it's empty?
Do you go 100 miles before the gas warning light comes on again?
A little more varification on how you know the tank still empty. I realize you probably have obvious reasons to say the tank still empty but in a case like this I just want to make sure all areas have been covered.
MIKE
Old May 14, 2004 | 05:06 PM
ferran586's Avatar
MIKE
He probably only ends up putting a couple of bucks in when it clicks off.
Old May 14, 2004 | 06:00 PM
fugi43's Avatar
I had the same problem. It seemed to only be at certian gas stations/pumps. I would just cram the nozzle in as far as it could go. Worked everytime.
05RLS2
Nov 7, 2016 05:52 PM
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
