Trunk won't open
Old Jun 9, 2004 | 09:21 AM
maxib2's Avatar
Trunk won't open
My trunk (97 GXE) won't open using the remote or the trunk release push-button. It does make a sound but looks like the lever/lock does not releases the trunk lid. It will only open with the key. I tried spraying some WD40 on the lever in the trunk (not on the lock assembly on the trunk lid) and it worked for a day but is stuck again.
Also, sometimes the radio antenna does not folds in completly, some portion of it sticking out. ... Any suggestions. Thanks.
Old Jun 9, 2004 | 09:24 AM
matty's Avatar
theres a switch in the trunck by the latch that will allow you to open it with the button and the key fob
-matt
Old Jun 9, 2004 | 09:29 AM
XeroX's Avatar
Hella internets
if you pop the trunk and look where there locking mechanizm is that locks the trunk lid to the car... there is a cut out in the carpet, in there, there is an opening where you can see a lil switch kinda thingy...
flip it up or down.. i dont member what way, but that is the lock so that when you park your car Vallet, you can lock your trunk so that no one unless they have the key can access the trunk.. kinda like a child lock...
Old Jun 9, 2004 | 10:26 AM
maxib2's Avatar
sorry, I should have mentioned this earlier..., I have already checked that switch and that is in ON position.
Old Jun 9, 2004 | 10:44 AM
FLO_BOY's Avatar
don't use WD40...it just evaporates.
put some grease in there!
FLO_BOY
Old Jun 9, 2004 | 01:24 PM
nitromax's Avatar
maxib2, mine doesn't have "on" or "off" on it, but the lever in the trunk should be pulled UP to allow the remotes to work!!
Old Jun 9, 2004 | 04:17 PM
95-96Maximas's Avatar
You should pull it uip and down several times - it has a detent - make sure it is all the way up or down, else it will not work. If it does not work at all after trying this you may have to use a small socket wrench and gently re-align the closing mechanism then tighten it well AFTER yu fixed the problem
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
Sep 27, 2015 08:37 AM
