10" Flip Down Installation??????
I just bought a 10" Flip down monitor. I was wondering if anyone knows if there is a write up on how to install one of these? I tried looking but got tired. Anybody with advice is welcome. Thanks in advance.
well briefly you need to take the headliner down (obviously) and you either use the metal piece that came with it or like the pro (pun) place my friend went to a thin piece of wood. the wood is so you don't have to line up the screw holes. its pretty simple. run your hot wire to the iginition wire and run the ground to a ground. i don't have maxima specific directions cause it was on a caddy. good luck i can go into more detail if you need.
You do not need to remove the headliner. Simply a small hole for wires, and slide in a sheet (12X12) of ABS to screw into. Wood can be easily done as well, but humidty will affect its use.
--Don
--Don
MaxLife17
Jun 27, 2019 01:37 PM
