Went to the dealer for my high idle....
and they took 3 1/2 hours to tell me to come back on Tuesday.......
I just sat at nissan waiting for them to finish and they tell me they need more time to find out what's wrong....I said go ahead and they say come back Tuesday.
I need to go again and this time leave my car there....This will take the whole day.....
I don't want some ******* to rip on my baby
thats why i say dont go to the dealer......they suck and always want your car there for days and want you to have to come back agian and never fix the problem
ive had enough bad experience with my dealer to never go back
-J
-J
-J
-J
) I'm still going to go cause i have nothing better to do and hopefully they will fix it.........they think it's a bad wire or something with the ECU or E something.........
Originally Posted by takkar
How high is it idling?
SO TUESDAY it is.....hope they fix it this time.....
Originally Posted by saxdogg
Did you leave in your intake or stock it?
Also, did you try the idle air learning procedures/resets?
JP
JP
Yes I did that for about a week and got tired of trying that's why I went to the dealer.... PLUS I have 1 year of warranty left so why not use it....I am patient when it comes to my car so I can sit at the dealer the whole day and wait...
Originally Posted by Ben
You should test voltage on the system and see if it is dropping way low just before the idle jumps up.
Let us know what they say.
Originally Posted by MaximaVQ97
could be the TPS?? but how stupid of nissan they spend 31/2 hours on youyr car doing what? did they even plug in the consult 2? usually with the consult you can move the idle up and down..
They're not a bad dealership though....didn't question anything (my foglight rewire nor my LED blinker taps)
Originally Posted by charliekilo3
Weren't you to one that said your idle speed went crazy after you cleaned your throttle body?
750 is the correct idle for Auto.....
Yes I am...
I recently had my car in twice for SES o2 sensor issues. After replacing the o2 sensors and I got the car back, noticed the idle was a bit higher than normal, but didn't think too much of it. SES came on 4 days later. Took it into Nissan and the adjusted the idle and reset the SES free of charge. They even shuttled me to and from my house twice in that day so I wouldn't have to sit there and wait. In my case, I have had nothing but good luck with the service provided by my Nissan dealer. Hopefully they can get it figured out for you.
Originally Posted by celica
unplug the battery i'm tellin u its goin to idle high again after u put the intake on. but since u already went to the dealer just get your new tb and then do the battery thing.
U bent the throttle plate while cleaning the throttle body, Why the idle is now higheer. I coulda told ya that in 5 seconds worth of diagnosis. U can't force open the drive by wire throttle body open. Tell us how much that throttle body costs when they repleace it btw
For what it's worth....
The same thing happened to me after I cleaned my TB. I have a 2002 I35. I took it apart and opened and closed the plate by hand while cleaning it. I did not do it while the car was on. Afterwards, the idle was at 1K and would not go any lower. Also the downshifts were more noticeable and the SES light came on.
I reset the ECU and did the idle air thing and nothing made a difference. The light still came right back on and idle was still high. I took it to the dealer and they could not figure out what was wrong so they ordered a new ECU. After they installed the new ECU and programmed it, everything was fine.
I still to this day do not know how cleaning the TB could damage the ECU but I guess some mystery's go unsolved. I do not think that you bent the plate. It's not THAT thin.
There are some sensors near the openning at the throttle plate...perhaps you dripped the cleaner onto it?
I had cleaned my throttle body at least 4-times and I never had any issues. The last time I took off the throttle assembly and clean the whole thing (I did the sparkplugs changed) and still nothing weird happen...the car idles perfectly at 650 rmp once warmed.
-For those who going to clean their throttle body, do not press hard on the throttle plate by trying to clean the back end of it. I believe there is a mechanism that control the plate by the ECU's for the 02'-newer model. Always try to be gentle when servicing the electronic control devices!
Originally Posted by Chinkzilla
**YOU HAVE TO DRIVE AROUND FOR LIKE 30 MINUTES FOR THE NEW IDLE TO STICK AFTER THE BATTERY RESET, AND IDLE LEARNING**
jeez.
jeez.
jeez.
jeez.
how long did u have yours unplugged? i had mines unplugged for over 2 days
No matter though....I dropped the car off at the dealer and they say it WILL be done today....I really hope they do finish it without giving me a problem.
GOD DAMN DEALER just called me to ask me to keep the car until tomorrow......
I wrote down the mileage so if they drive it i can know for sure...... (hope the headlights will be okay.....
hmm.....high idle.. then I think mine is weird too...Sometimes it's about 800, sometimes it's about 1200. Are you guys sayin the rpm/min stuff? But my car is alright I think. I havn't done any mod to it since I got it a month ago and I got no money right now.
They will likely do a test drive if and when they fix your car so there will probably be additional mileage on it.
If i see more I will be complaining to nissan and taking it further.....
I got my TB cleaned a few weeks ago and noticed that the idle is higher now. It idles at 900 when in P ( ihave an auto) and roughly 600-700 when I put it in drive...is this what you are seeing MaximaPolak?
Is this normal for me too? when someone says they are idling higher..is that when the car is in P or D?
litch
123
Jan 4, 2024 07:01 PM
