TUNE UP Question!!
Old Mar 31, 2001 | 10:37 PM
wizard6161's Avatar
ok guys..I want to tune up my car. what should I change or replace? thanks for your help!!
Old Apr 1, 2001 | 12:15 AM
wizard6161's Avatar
also ....I would like to know if any of you guys has an engine oil cooler in you cars..and if you know a site that helps on how to install it thenI would really appreciate it. thanks
Old Apr 1, 2001 | 07:58 PM
Chris Gregg's Avatar
Get Off My Lawn
I looked at oil coolers but was told the benifits were meager on a V6 unless really running your max hard almost all the time. Are you talking about a "tune-up" or a rebuild? Tune up consists of wires, plugs, dist. cap, rot. button, pcv valve, fuel filter, check fluids, replace air filter and change oil. Next step would be O2 sensor and maybe even a timing belt. I'm looking at a rebuild, which consists of (but not limited to) pistons, boring, gaskets, valve job, etc. I'm also looking on adding Stage II cams and JWT ecu. But, depending on cost, I may just go ahead and do the infamous "z" upgrade. Too bad no one will disclose their costs! Hint....Hint! I know the engine is under $1k, I've called. But, with the swap, wiring, and ecu, what is the final dollar? Hey, if it's under $3k, consider it done! So, how about the price? Anyone?
Old Apr 1, 2001 | 09:39 PM
superdesi's Avatar
If you do not know what a "tune-up" means, then probably you should take the car to an auto repair shop and have the professionals handle the job.
Old Apr 1, 2001 | 09:58 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Yup.......
not to say that he couldn't do it, but the way I learned was to watch my mechanic do mine the fist time, then come the next tune-up I grabbed my Haynes manual and got to work and finished with no probs!
Old Apr 1, 2001 | 10:02 PM
superdesi's Avatar
I agree
Tune-ups in almost every internal combustion engine out there involves replacement of the same components.
Obviously if the vehicle is a distributorless (direct ignition) model, then you would not have to worry about rotors, caps, etc.
Old Apr 2, 2001 | 08:52 PM
wizard6161's Avatar
thanks but I have another Q!!
ok guys thanks for you help. I got all the components I need to perform the tune up on hte car *spark plugs, dist. cap , wires, oil, filter* . but the guy at the auto zone said " well you may wanna go ahead and cahnge your timing belt" . so my question now is that how hard is it to change the belt? anyone has done it themselves? if so would you post the steps here ? thanks in advance.
Old Apr 2, 2001 | 09:03 PM
superdesi's Avatar
Re: thanks but I have another Q!!
If I were you, I would cough up the $300-450 it takes to have it changed professionally.
Old Apr 2, 2001 | 09:06 PM
thebull's Avatar
Re: Re: thanks but I have another Q!!
yeah, i havnt done the timing belt change myself, but i heard it was pretty time consuming and you need some special tools. i got an email with the proceedure from someone on the board. ill try and find it and email it to you.
litch
123
Jan 4, 2024 07:01 PM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
Maxboy23
Sep 4, 2015 06:04 PM
