Error code 0301 - replace ECM. Is this critical?
Old Jul 6, 2004 | 07:55 AM
High Desert 95SE's Avatar
My husband says since the car runs fine I can ignore the error and not replace the ECM. I think it should be replaced.
Can anyone advise the correct course of action?
Please help this girl who loves her 95 SE!
Old Jul 7, 2004 | 10:59 AM
slvr2KSE5's Avatar
P0301 is a misfire on cyl #1. why you would have to replace the ECM is unknown to me.
clear the code and see if it returns. you should be able to feel a miss.
Old Jul 7, 2004 | 11:07 AM
Kevlo911's Avatar
Kevlo for President
No it's not. PXXXX are different from DTC read by turning the screw on the ECU.
Like I told you earlier, I would replace the ECU, do you know anyone with a 95-96 maxima or I30? If so, swap out hte ECU for a few hours and see if you get hte code on their ECU or if you car runs better with thier ECU.
Old Jul 7, 2004 | 01:21 PM
slvr2KSE5's Avatar
my bad. P0605 = replace ecu.
Old Jul 7, 2004 | 02:17 PM
DR-Max's Avatar
Where is Phelan? I'm in So-Cal with a 95 SE, 5 speed though. I'm pretty sure it doesn't matter.
Old Jul 7, 2004 | 02:24 PM
Phelan is in the high desert - near Victorville.
As I understand it, the ECU must be for an AT.
Old Jul 7, 2004 | 02:35 PM
DR-Max's Avatar
Hmmm.......I gotta find out from Nismo if that is so. He had an automatic and converted to manual. He didn't mention about changing ECU too but his is a 97-99 GXE. Come to think of it, I think he got a 95 ECU since they are better than the others.
Old Jul 8, 2004 | 04:47 AM
Kevlo911's Avatar
Kevlo for President
From my understanding, you can use an AT ecu in a Manual but not vise versa. I guess you could in this situation because it is only a test. ou will prob get other codes but that is ok.
mrc00l88
Jan 25, 2024 01:14 PM
lux97Max
19
Aug 27, 2015 07:48 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
maxima297
Aug 3, 2015 12:50 PM
