2K2 Injen Problem
Old Jul 9, 2004 | 03:47 PM
zachary1988's Avatar
2K2 Injen Problem
I have a 2002 Maxima with 6 speed. I recently purchased a new RD1940. I am having a problem where I cannot bolt it down to the water outlet as it is described in the instructions. Right now, it is being held on just by about 1/8" off the washer and not the bolt(secondary or longer aluminum piece). I was wondering if anyone can take a close up picture of their MAF sensor and send it to me so I can compare it with mine. I'm just wondering if that is the problem of maybe mine may be longer than the rest. I appreciate any help. Ed. edkim58@hotmail.com
Old Jul 9, 2004 | 05:01 PM
Maxpat82's Avatar
I've got the same problem on my 2001!
So I cut about 1/4-3/8 inch off the tube near the MAF!
Now everything bolt as it should be!
Fittment issue on a piece of that price suck hard though
Old Jul 9, 2004 | 06:45 PM
2k2kev's Avatar
It's chrome alright...
I have an injen on a 2k2 and have no idea what you're talking about... everything on mine fit perfectly.
Use these pictures... what are you talking about? (ignore the circle... was for another topic)
Old Jul 9, 2004 | 08:06 PM
2MuchMAX4U's Avatar
I had no problems installing the injen on my 2k1 but it did take a little bit of tlc to get it to line up properly. I suggest taking a look at it again and making sure all the fittings line up properly.
Old Jul 9, 2004 | 08:40 PM
96maxdaddy's Avatar
MInes a fourth gen, but it fits the same way. Anyway i had that problem, and all i did was CAREFULLY bend that piece to were I needed it. I t wasnt hard to bend cause its made from soft aluminum.
Old Jul 10, 2004 | 09:34 AM
Audtatious's Avatar
Bandwagon Lover
The only problem I had with mine was the lower intake. I had to bend the bracket a bit to get it to fit on the tranny tube mounting bolt (automajic).
Old Jul 10, 2004 | 10:23 AM
Excellent pictures. By the way, where you have a circle is my problem. I have taken it off and put it back on three times and that bracket where it is suppose to tie down to the bolt on the water inlet piece of the longer aluminum piece will not reach. The other thing is that mine is about 1/2" away from the fan shroud. Yours looks as if it is about 1"-2" away. It is amazing how others have the problem with their's also. Could you take a picture of your MAF? For some reason, it looks shorter than mine. Again, thanks for your help and others who have replied. I hate to say it like this but I felt like I was the only one who had a problem with it fitting properly.
Old Jul 10, 2004 | 06:15 PM
fornimage's Avatar
One thing I can think of doing is to make sure that the rubber sleeves are properly "seated" meaning the tubes are butted as far as possible together.
Old Jul 10, 2004 | 07:17 PM
2k2kev's Avatar
Hope these help... click for a larger version.
I did not need to bend anything to make it fit. I did have a hard time the first time because I tightened up the "cover sleeves" (not sure the real name...the red rubbery connectors) too tight. Once I loosened them it was much easier to twist into the proper position, then I tightened everything down all the way.
The MAF tube is 5", maybe 6" long.
Old Jul 10, 2004 | 07:32 PM
MaximaPolak's Avatar
I don't have problems on mine.... why would you?
Old Jul 12, 2004 | 06:05 AM
Again, thanks for your help and the pictures. It will be a great help. I will try to loosen the rubber connectors and try again. Ed.
Old Jul 12, 2004 | 07:54 AM
That's not the problem. Can I ask one more favor from you to measure the top of bracket(where the weld is) to the end of the longer aluminum piece(it goes into the MAF)? My coworker thinks that the bracket may be welded in the wrong spot. Mine appears to be about 5.5" from the end to the top of the weld. Again, I am only asking since I just purchased the RD1940 since mid May and have no cooperation with the company I purchased it from and Injen. Thanks, Ed.
That's not the problem. Can I ask one more favor from you to measure the top of bracket(where the weld is on the first picture)to the end of the longer aluminum piece(it goes into the MAF)? My coworker thinks that the bracket may be welded in the wrong spot. Mine appears to be about 5.5" from the end to the top of the weld. Again, I am only asking since I just purchased the RD1940 since mid May and have no cooperation with the company I purchased it from and Injen. Thanks, Ed.
Old Jul 12, 2004 | 08:36 AM
2k2kev's Avatar
From the looks of it the bracket is welded on about 4.25" from the end of the tube (the green line). I can't be 100% sure but if I jam my finger down on the sleeve that's where the end seems to be.
Hope this helps.
Click for bigger version.
Old Jul 12, 2004 | 09:03 AM
Hope this helps.
This helps out a whole lot! Thanks for all of your help! Like I said, mine appears to be about 5.5" compared to your 4.25". This is why I cannot tie mine down and it is only hanging on by the washer and not the bracket. I guess I will have to take everything apart again and send the longer aluminum piece back to Injen. I just hope they send out a new one asap. Again, I appreciate your help on this one. Ed.
Old Jul 22, 2004 | 11:06 PM
I finally received my new longer aluminum piece from Injen. Paul Ho, who I have been dealing with since I purchased the RD 1940 new two months ago could not understand what went wrong with the manufactured piece I had. The bracket to tie down the whole thing was welded in the wrong spot. Again, I want to thank you for your help in taking the pictures. Ed.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
