Installing speakers in 02 maxima
Okay so i bought 2 pairs of planet audio 6.5" speakers. I'm looking to install them today before the sun goes down but we'll see what happens. I was wondering if there is any link where I can figure out how to take the door panel off. I found one bolt, but think there might be 2 more hidden where i can reach because i cant get the door off. gladly appeciate any help at all.
thanks
thanks
Theres one that holds down the window switch, then you have to pry out the switch. I believe then there one behind the switch and the one that is on the front of the door and your done. Then just pull with some force and the clips should come out, if you start to pull and you feel like its too tight then look around that area.
brandon
brandon
brandon
brandon
Also I was looking at the switch to maybe solder in blue lights, but i cant even figure where there are to replace them. so im having a long long day. thanks you for help.
The ones under the plastic do not come off. The mirror thing does not have a screw behind it that needs to come out, on my 2000 there are 3 screws total i believe then the whole door panel comes off. Its the one holding the switch the one under it then the one where the clip is on the outside of the door near the mirror cover. Then just pull from the bottom it should come off
brandon
brandon
jskirwin
Jun 8, 2016 08:49 AM
Team STILLEN
Aug 10, 2015 04:29 PM
