fog lights
Old Apr 2, 2001 | 10:15 PM
geo1317's Avatar
my friend just got a 97 maxima GLE and he wants to put in the factory fog lights, i have heard that the car comes pre wired for them. Is this true? And if so what elso other than the lights does he need to buy? (relay, switch, etc...).
thanks for any help
Old Apr 2, 2001 | 10:36 PM
Matrix's Avatar
I just looked into this:
You can buy the kit for $176.00 plus shipping from Courtesy Nissan.
If you have the lamps you need to buy:
$11.06 relay
$28.40 each mounting bracket
$52.32 control switch
The wiring is already there in your car, its just taped up with the other wiring behind your headlights/clearance lights.
Old Apr 2, 2001 | 10:39 PM
geo1317's Avatar
where is the wire on the interior and where would the switch go?
Old Apr 2, 2001 | 10:56 PM
Matrix's Avatar
go here:
The wiring is in the harness directly behind the LEFT headlight I believe.
The Switch is actually just a straight-up replacement of your current signal/headlight control switch on the left side of your steering wheel
Go to cheston's site, he has the fog lamp install instructions up there:
http://www.bol.ucla.edu/~cchiu1/fogs.html
Old Apr 3, 2001 | 11:57 AM
geo1317's Avatar
i just went to courtesyparts.com and it said $227 for the 97-99 kit. Did the price go up or something?
Old Apr 3, 2001 | 12:10 PM
GaMax97GLE's Avatar
That's about what I paid...
I did this same thing with my GLE a couple of months agao. My car was pre-wired (like all GLE's) so I just had to buy the fog lamp kit (lamps, bracket, & new lever) from Courtesy and install.
You will need to (off the top off my head):
1) disconnect battery
2) Cut the plastic piece in the bumper where the fog lights go
3) mount each light and connect to the wiring already there that's wrapped in grey tape
4) take apart your steering column to access the wiring there
5) remove your old turn signal lever, install the new one with the control for the fog lights and reconnect it to the wiring harness
6) put your steering column back together
7) reconnect battery
8) enjoy your new fog lights
*there is also a way to rewire your fogs so they come on without having your headlights on but I haven't done that. This is the stock setup that I explained
Hope that helped...
Old Apr 3, 2001 | 12:18 PM
bdogg88's Avatar
I just went to courtesyparts.com and couldn't even find the kit.. can someone put down the exact link.
Old Apr 3, 2001 | 12:32 PM
GaMax97GLE's Avatar
Here you go...
Fog light link: http://www.courtesyparts.com/onlines...=a32_quicklist
Temp. part listing for 4th gen.: http://www.courtesyparts.com/onlines...=a32_quicklist
(Hope that works...)
Old Apr 3, 2001 | 02:03 PM
WaarrEagle's Avatar
If you get a price through e-mail they will give you $176. If you call they say over $200. I called and they gave me the high price and I just told them I was told 176 online and they gave it to me for that. Good luck.
Old Apr 3, 2001 | 06:27 PM
strattao's Avatar
Re: That's about what I paid...
Hope that helped...
Ok, here is a long shot...
I have a 96 GXE. I hate the front bumper, and the fact that I have no fog lights. What are the chances that I could put on a 97-99 front bumper, and install those fogs?
Old Apr 3, 2001 | 10:17 PM
Matrix's Avatar
a good chance
Goto Ebay
there is a 97-99 Front bumper cover on right now.
http://cgi.ebay.com/aw-cgi/eBayISAPI...item=575944023
Old Apr 3, 2001 | 10:55 PM
Weasel's Avatar
Re: a good chance
Originally posted by Matrix
Goto Ebay
You have to buy a new grill also, the 95 and 97-99 are not interchangeable.
Old Apr 3, 2001 | 11:12 PM
Matrix's Avatar
tada!
thats ALSO on ebay
http://cgi.ebay.com/ebaymotors/aw-cg...207468&r=0&t=0
Heck, you can get the fog lights there too:
http://cgi.ebay.com/ebaymotors/aw-cg...538463&r=0&t=0
but you are better off getting the Courtesy kit.
Old Apr 4, 2001 | 03:55 AM
bdogg88's Avatar
Re: Re: That's about what I paid...
You can do it relatively easy but i wouldn't reccomend it. You can buy the set of fog light kit from a 95-96 and not have to change the entire bumper and still get the fog lights. Unless if you really want to change the bumper that bad. You're the boss.
Old Apr 4, 2001 | 07:01 AM
strattao's Avatar
Re: Re: Re: That's about what I paid...
Why wouldn't you reccomend it? I hate the ugly 95-96 bumper, and I think that the 97-99s are a definite improvement. I didn't know about the grille though, hmmm.
Old Apr 4, 2001 | 11:13 PM
Matrix's Avatar
go ahead
This isn't a difficult conversion.
However, it will set you back around $400 (including paint job of new bumper), assuming you do all the installation yourself
Old Apr 8, 2001 | 06:23 PM
KCTYPHOON
Re: Re: Re: Re: That's about what I paid...
i agree that the 97 header is much nicer.. a friend of mine was gonna do it to his 96 and was told that he also had to change the metal bumper behind the header panel also..i could be wrong. u might be better off trying to find one in a junkyard, then you may be able to get the header, bumper, grille, foglights, and may even wanna upgrade to the newer headlights too..all in one shot
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
