Removing Tranny
Old Jul 30, 2004 | 08:02 PM
Lamar's Avatar
Removing Tranny
Is it possible to remove the tranny from my 89 Maxima without pulling the engine.
Old Jul 30, 2004 | 08:07 PM
-shock211-'s Avatar
yes,
remove the driveshafts, unplug the sensors, unbolt the tranny mounts, unbolt the tranny from the engine and you're set. well, that's a simple explanation at least. it's not that hard.
Old Aug 17, 2004 | 09:14 PM
maxok's Avatar
5 speed or Auto
Is this possible with the Automatic or just the 5speed ???
Old Aug 18, 2004 | 11:09 AM
subs1000w's Avatar
you can pull either of them without pulling the engine
Old Aug 18, 2004 | 11:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
5 spd is easier.
auto is a tight fit.
make sure you strap down/support the engine or it's going to break something when the weight goes off it.
Old Aug 18, 2004 | 01:47 PM
mtcookson's Avatar
its usually easiest to put a jack under there with a board between the jack and oil pan. i prefer the screw jack supplied with the car since it can't "leak" like the hydraulic jacks can. if i remember correctly the jack needs to go on the belt side of the engine, under the oil pan.
Old Aug 18, 2004 | 06:50 PM
5 ltr. beater's Avatar
yes you can. I'm actually quite a pro at it by now. i've taken my tranny in and out 4 times within the past month. I can have my tranny out and then back in again in just over 4 hours (thanx to air tools and a lift at my work). I just installed my new tranny since I blew the other one up by doing the drop resistor mod. e-mail me if you have any questions.
my03maxima
Jul 28, 2024 07:40 AM
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
jaydot901
Sep 29, 2015 01:18 PM
