Igor's rewiring fog with high-beam on
Old Aug 23, 2004 | 02:17 PM
Bl_asd's Avatar
Thx to housecor, 've rewired my fog with parking light. Now i wanna do Igor's wiring. The problem is, I still not sure which wire I should cut. The white little connector ( the little one right next to light switcher for '00) has 2 wires. 1 is green and light ornage strip and the other 1 is green with yellowish stripe. i think i should cut the green with yellowish stripe. Need some confirmation before i do it. Also...which spot is the best for grounding...i can't get the bottom column cover off. it kind of stuck there...can i ground on any screw even it's not attached to metal?( i think not)
Old Aug 24, 2004 | 04:40 AM
Bl_asd's Avatar
need help...sry for the bumping...
Old Aug 24, 2004 | 05:39 AM
2k2kev's Avatar
It's chrome alright...
Have you tried PMing him, rather than bumping this?
Old Aug 24, 2004 | 06:19 AM
Igor911's Avatar
Are you looking for the same connector that I show in the picture?
The wire on a 2000 is Green/Yellow. As for the grounding...you can either ground it to another ground wire or ground it to something in the steering column. And for the peice of dash u cannot take off, try to pull it a lil bit, sometimes it gets stuck.
Old Aug 24, 2004 | 07:05 AM
Bl_asd's Avatar
can i ground the wire to the wire right next to it(green/ornage stripe)? I mean..can i cut that wire and use connector to connect them all together?
Old Aug 24, 2004 | 07:10 AM
Igor911's Avatar
I'm not sure dude. Just if you don't want to fry anything, please follow my directions. If not, your on your own. I took the time to research this correctly. 1 wrong move and you will break fuses and cause shorts or what-not
Old Aug 24, 2004 | 07:15 AM
Bl_asd's Avatar
Alright ,thx a lot i"ll see what i can do..
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
