What size Intercooler?
Old Aug 24, 2004 | 10:50 AM
BlackCat's Avatar
RIP '98 Maxima SE
I thought that I bookmarked a recent thread about the proper intercooler size for our Max but I lost it. Could someone post the size? Thanks!
Old Aug 24, 2004 | 12:03 PM
Chunger's Avatar
My other car is a Hybrid
As big as you can fit... to reduce backpressure... although most of it will be from piping.
If you are talking about fitting w/o cutting the bumper supports, etc... I'm not sure.
Old Aug 24, 2004 | 01:18 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
"As big as you can fit" is typically the advice for a turbo, but not a SC.
The larger the core, the more volume to pressurize and thus more lag.
You'll need to drop down a pulley or two to compensate, however only if you can still go smaller without exceeding the SC max impeller speed.
Old Aug 24, 2004 | 01:30 PM
Chunger's Avatar
I may disagree with ya on that one.... goal is to reduce temperatures while having as close to no drop in boost.
Unless you have a grill the size of a semi truck it would be nearly impossible to introduce a "too large of a volume" intercooler that would give you lag (even on a supercharger which doesn't spool up).
Personally on our SC... I don't feel that FMIC are a viable option anyways... I'll leave this one open to debate but I don't see and evidence showing that there ISN'T *significant* boost loss due to piping (and/or core).
Old Aug 24, 2004 | 01:33 PM
BlackCat's Avatar
RIP '98 Maxima SE
I'm just looking for the dimensions, folks. It was posted here but not after the server crash.
Old Aug 24, 2004 | 01:41 PM
MaXtUneD's Avatar
Mine is 33x6x2.5..heres a pic..i know mine is a 3rd gen and you have a 4th gen but i hope this gives you an idea...thinking about going bigger though...still got enough room up top...
Old Aug 24, 2004 | 02:34 PM
nateplaysbass's Avatar
I fit a 24x12x3 inch core: 31" from tank to tank.
but I had to take a grinder to the back side of the bumper to take off the lip that sticks backwards on the lower edge. As well as cutting the hood latch support, which makes hood pins necesary
Nate
Old Aug 24, 2004 | 02:46 PM
IceY2K1's Avatar
I think you are correct.
Using a 3L NA engine at 2000rpm injests ~105 cubic feet per minute, so a huge 0.5 cubic feet IC would take <0.3 seconds to be aspirated. Interesting....
However, I still call your V1/V2 a LAGcharger.
Old Aug 24, 2004 | 03:54 PM
Stephen Max's Avatar
It takes a bit of doing, but you can route the piping to produce very minimal boost loss.
http://forums.maxima.org/showthread.php?t=328904
I saw a drop in boost pressure of only about .2 psi with this setup. Now if I can find an intercooler with only about one psi of loss, I think I can go with the 2.87" pulley and come out ahead.
Old Aug 24, 2004 | 03:56 PM
IceY2K1's Avatar
If cost isn't a concern....
http://www.bellintercoolers.com/
Old Aug 24, 2004 | 04:19 PM
Chunger's Avatar
Looks nice...
I was going to cut around that area but from what I saw it was right over the frame (vertical wall) so I scraped the idea.
So the difference in PSI reading just after the SC outlet and at the TB is only 0.2 PSI? That IS negligible... the IC (if it is large enough) should only have about 0.25 PSI less drop.
Old Aug 24, 2004 | 04:39 PM
Looks nice...
No, not exactly. Comparing boost pressures at the intake manifold from before and after the rerouting of the piping resulted in .2 psi difference. I'm datalogging using a GM 2 bar map sensor, so I have accurate before and after data to look at.
Miket2006
Mar 1, 2021 03:55 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
knight_yyz
Nov 1, 2015 01:34 PM
