Ignition problems, please help
Old Aug 25, 2004 | 10:23 AM
sathishrao's Avatar
I had problems with the starter about 6 months ago. I replaced the starter and later on found out the problem could have been fixed with a new grease pack in the starter. Since last 4-5 months, I am having problems starting the vehicle. The engine cranks and has problems starting when I start the car. I only have the problem if the engine if cold, meaning if the car has been parked a little while. After it starts once, then if I turn the ignition off, and then restart, I dont seem to have any problem. I am having a hard time figuring out what the problem is. Could it be the fuel filter or a clogged injector ?? It doesnt seem electrical, because, I can hear the engine cranking and trying to start. But, while trying to start, it causes a loud screeching noise. Almost sounds like the gear teeth are slipping. Please help.
Old Aug 25, 2004 | 01:00 PM
f550maranello2's Avatar
man every one has the damn problem (including me)why cant anyone figure this out i changed the fuel filter the plugs cleaned the tb, the IACV, the crankshaft senstor the camshaft sensor and many other things and it didnt help yet.
Old Sep 8, 2004 | 12:55 PM
abongo's Avatar
Check or replace your ignition switch.Had the same problem and i replaced the ignition switch and never had the problem starting again.
shilov
Feb 19, 2024 09:40 PM
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
ajahearn
Sep 19, 2015 03:03 PM
rnb754
Sep 14, 2015 11:39 PM
