Thinking about running a 2.87 pully on my charger WHAT DO I NEED?
Old Sep 10, 2004 | 02:27 PM
mighteatyou's Avatar
Thinking about Getting the V2 Supercharger Setup.
Basically i wanna run the 2.87 pulley. What do i need to do it as far as the fuel managment ect ect?
This is what i have installed thus far:
Exhaust:
Cattman Headers
Cattman Y-pipe 2.5
Random Technology Cat 2.5
Stillen B-pipe 2.5
Stillen Muffler
Middle Eastern Variable Intake Manifold
Suspension:
Tokico Illumina adjustable Shocks
Stillen Front Strut-bar
Stillen Rear Strut-bar
Stillen Rear Sway-bar
Eibach Springs (1.5” Drop)
Stillen Adj. Camber Plates
Brakes:
Stillen Slotted Rotors Rear
Stillen Slotted Rotors Front
Matrix Kevlar Pads Front
Matrix Kevlar Pads Rear
Stillen Brake lines
Motul Brake fluid
Transmission:
Redline MT-90 Transmission Fluid
ACT Stage 1 Street Clutch
Fidenzia Flywheel
Unorthodox Drive Crank Pulley and Belt
Stillen Short Shifter
I have the V2 Kit in front of me uninstalled along with the Boost gauge,EGT gauge, and fuel pressure guage.
i figure i need the following items:
-Walbro 255lph
-300ztt MAF
-adjustable fuel pressure regulator
-JWT Chip with 550cc injectors(tunned for MEVI and Supercharger)
-i know i need a fuel management of some sort. but what route should i go too push this setup??
anything else i need? i mean honestly tell me everything, i want too have the PERFECT SUPERCHARGER setup! and push as much horse as possible
thanks in advance
Old Sep 12, 2004 | 04:53 AM
iansw's Avatar
I'm using a JWT ECU and 370cc injectors....I do lean out a little up top (need the Z32 MAF program from JWT)...but she does run well.
I don't think you need 550cc Injectors...that's overkill.
Old Sep 12, 2004 | 08:17 AM
n e 1 else?
n e 1 else?
Old Sep 12, 2004 | 08:34 AM
matty's Avatar
You'll need to put back on your Stock Drive Pulley...and pick up a new seal from Nissan while your at it
-matt
Old Sep 12, 2004 | 01:02 PM
oh yeah, hmm i hope i still have that pulley haha. anything else?
Old Sep 12, 2004 | 07:18 PM
Kenneth's Avatar
OG :)
2 step colder plugs at least.
Old Sep 12, 2004 | 08:23 PM
iansw's Avatar
I've been running on 1-step colder (and running lean up top due to MAF issues - which I'm working on fixing) and haven't detonated once all summer....and I drive it like I stole it....with a 14:1 A/F at 6800RPM....
Man I love this engine!
<I probably just jinxed myself....>
<knocks on wood....>
Old Sep 13, 2004 | 06:12 AM
Prodeje79's Avatar
Do you set your BOV to vent off any excess boost?
Do you try not to exceed any certain PSI?
Old Sep 13, 2004 | 05:54 PM
VQ30DES's Avatar
I have a 2001 with a supercharger running the 3.125, and still have the stillen intake piping which takes away 1psi so i am running 10psi. With a 5th gen my injectors and maf could support the 2.87, correct? Also how many psi are you seeing with the 2.87, and do you have a cold air intake. Because i should get 12psi with the stillen intake i have currently, would that mean i would get 13psi w/ cold air intake like people put on 4th gen, wouldn't that be too much? Also i guess this goes for both gens, would i need WI or anything?
Old Sep 22, 2004 | 09:45 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
The 5th gen injectors can handle it, but it's not "recommended safe" pushing those fuel pressures and duty cycles. You can upgrade to plug-n-play 380cc($670 used), 510cc($870new), or spacer-n-splice 440cc($325 used/$400ish new) or larger. However, you'd need an eManage($275), ignition/injector($65) harnesses, and Support Tool($100). The eManage would allow you to retard timing, which is what you really need to be "safely" pushing 10+psi.
vybz05
Dec 10, 2015 07:38 PM
max_speed97
Aug 26, 2015 07:46 PM
JMag90
Aug 25, 2015 09:17 AM
acw
Aug 13, 2015 12:50 AM
Wolvee
Aug 11, 2015 12:24 PM
