Amp kits...
Old Sep 17, 2004 | 03:06 PM
Max96Se's Avatar
Amp kits...
$24.64 - 1100-Watt Car Amp Wiring Kit, KPA4X2:
http://www.walmart.com/catalog/produ...uct_id=1863080
Anyone use this? Seems like a good deal.
Old Sep 17, 2004 | 04:13 PM
nostrixoxide's Avatar
I've never used one of those kits before, but i have noticed a few local shops are starting to use Scosche products.
Old Sep 17, 2004 | 09:46 PM
Max96Se's Avatar
From what I've seen, if its of any quality at all, than its a good deal for $25... isnt it?
slickrick's Avatar
not bad but it doesnt have alot of power cable. check out knukonceptz on ebay to get a solid deal on decent wiring.
Old Sep 18, 2004 | 08:21 PM
generation3's Avatar
Its from walmart how good can it be?
Old Sep 18, 2004 | 08:42 PM
AscendantMax's Avatar
oxygen free copper is oxygen free copper. my 12 gauge speaker wires i'm using are from walmart, and everything sounds fine.
Old Sep 18, 2004 | 10:20 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Actually not entirely true. Although for the typical basic system it doesnt really matter much. Other things to take into consideration would be : Strand count, Thickness of strands, How tightly wound it is,etc..
I was having fun with someone the other day comparing Lightning Audio, Scosche, Metra and Stinger...There is quite a visable difference between them.
Typically you would want to find a high strand count, very thin, Very tightly wound. This is the prime reason you dont see competitors using welding cable. Although it is a Much cheaper alternative the thread count is extremely low, and strands are extremely thick, making it almost impossible for tight bends as well.
--Don
Old Sep 19, 2004 | 12:34 AM
darrick's Avatar
Dallas Nissan Enthusiast
Don is right (like always) I was running a kit like this for years with my rockford amp after upgrading to a higher end amp I had engine wine I could not get rid of after trying every thing in the book to fix this I changed to stinger helix rca cables and BAM no mo wine .good luck
Old Sep 19, 2004 | 09:42 AM
--Don
i stand corrected. seems to me that some wiring kit's price are elevated just because it has some big company name stamped on them.
Old Sep 19, 2004 | 09:49 AM
slickrick's Avatar
it does but i had monster cable 4 gauge and when i got some stinger cable i liked it much better. so its a coin toss pretty much.
Old Sep 19, 2004 | 10:18 AM
Pearl96Max's Avatar
Well you are still correct in that aspect. The prices are raised due to a name, not just quality. If an off the wall company made the same exact product as say Stinger for example it would most likely be dramatically cheaper.
--Don
Old Sep 19, 2004 | 10:48 AM
Conrad283's Avatar
I need a truck
Just remember. You get what you pay for.
Old Sep 19, 2004 | 01:16 PM
sachmo12345
what would be the best amp kit for like 50$$
Old Sep 19, 2004 | 03:34 PM
slickrick's Avatar
a stinger or knukonceptz kit.
Old Sep 19, 2004 | 09:47 PM
Saddles's Avatar
The power wire and remote and ground wire will all be fine in that kit. Just to let you know the 4g wire will make it into the back seat. The RCAs are fine for subs, not for highs, **** load of engine whine. If you use that kit, you will either need to extend the power wire like i did...which was a pain twisting each strand together and covering it all in solder, or just use the splitter block type deal that comes with the kit, note you will only end up with 8g wire if you do this, which is fine for some people, but not for me when i amped all my highs and put more power to my subs.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
