Finally lower my car, but new problem right after :(
Hello there!!
Today after waiting for so long... i finally lower my car. 2.2 n the front and 1.8 n the rear.... car so super cool, but for months now i have had a problem starting my car. I would have to giggle the key up and down for the car to finally turn on. Today at school the car wouldn't start... it seemed like the battery was low. so i went ahead and got another battery. Now it's night time and the car wont turn on with the key. I would have to push the car to turn it on. At this point i know it's not my alternator, battery. Im not sure about the starter, but when i twiste the key it doesn't seem to be wanting to turn on at all. Please help me fix this problem. The car looks great, but it wont turn on :.(
Originally Posted by nostrixoxide
Mine does it too...oh you can teach yourself to start it, but I'm thinking I don't want this security feature....mine and my friend's car have the same problem. Where can I get this ignition switch? Btw. Turn key forward into 1st notch, then from there forward and hold...should do the trick.
Im not sure either but my friend has 96 Max (That just got ****ed up buy the way. SOme guy U-turned into him ouch...) but ya anyways. He only had 60k miles on the car but his ignition coil went out about 58k and his starter went out at 60k.. So nto sure. Fixed the problem though. Starts up faster than my moms ****ing 04 BMW. jeez...
Mine was starting to do the same thing at first i thought it was the battery because it sounded like it didn't have much power. After switching batteries I found out the bendix in the start wasn't wanting to engage all the time, went to O'Riellies and got another one for $50. haven't had a problem sence. before mine went out it seemed like it was taking longer to turn over then before, has it done that to you?
help me.... thank you
Originally Posted by mAxPwEr4Us
I have a CEL 04-07 which is Crankshaft Position sensor could that have anything to do wiht my car not wanting to start at all? PLEASE GUYS IM DYING HERE
It could be the ignition ______(don't know the name of it off hand) that comes off your ignition lock. This thing is used to turn on all the avaliable circuits in the car. This thing is located on the left side of the igintion lock(opposite side of where you stick your key in to start the car). It's probably worn out from excessive use. I had to replace mine when I couldn't get the car to start.
Hello!
Thank you for all yoru replys.... I FINALLY got the car to work
it was the starter, but im glad i changed the ingition switch b/c now i dont have to jiggle the key to start the car. Car is running great.... looks a lot better and im happy...
Once again thank you guys for all the input...
Peter
Once again thank you guys for all the input... Peter
Hello!
Peter
Originally Posted by CystumMax
A dead starter will not make your car start, A dead Ingition switch, nothing will come on when you turn the key to on position.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
....has nothing to do with lowering it
