CEL: intake?
CEL: intake?
Hey guys,
Today i put in a shortram air intake, when i put the shortram intake piping in today i also took the second hose that goes into the piping(towards the top of the engine bay) and put in a second breather(already had one on valve cover) and now i have a check engine light....before i had a stillen kit(maf and filter, stock piping) and i also had a K & N breather on the valve cover hole thingy, and i wasn't getting a CEL. I'd diagnoss it but the moron who had the car before me broke the **** off of the ecu so i cant do it myself....anyway my question is, do you guys think it is the intake piping, or breather, or both causing the light? and if so how do i fix it?
Thanks in advance.
Bashar
Thanks in advance.
Bashar
Originally Posted by Phatbashar
Hey guys,
Thanks in advance.
Bashar
Thanks in advance.
Bashar
haha, thanks man i could try to jam a coin in there.....JK but am I restricting air by doing that? would it be a better idea to cut a hole in the intake piping and stick the midpipe in there?
Thanks again
Thanks again
The hose the usually would connect from the valve cover to the midpipe/stock resonator is for recirculation/smog. If you have a breather on the vavle cover where the hose normally would be thats ok. But where the other end of the hose would connect on the midpipe it's not ok for it to just suck air in. It needs to be blocked off so it cannot suck air through that opening. It is un metered air, meaning the computer is not adjusting for it / suppling additional fuel to mix with the additional air. The computer is reading the amount of air entering the engine based on what passes throught the MAF sensor. Any extra air not metered by the MAF is bad. I'd be willing to bet if you try to drive the car the vehicle will sometimes run good & sometimes might stall out for no apparent reason. Well no you know the reason... So cap off the opening on the midpipe & you'll be fine.
no the cel is probely caused by the air inatke temp sensor. it is on the bottom of your stock air intake downpipe right before your airfilter if you had the stock one of there. check that and see if that is causeng your problem.
also putting a second breather filter on the upper one is not a good thing. that air needs to be measured.
i tried that(capping the midpipe), and the car wont turn on.....thats why i was saying to put a hole in the intake piping....are we talking about the same so called "midpipe", with the stock intake this pipe goes into the intake behind the airbox.....
I know alot of orgers that do not put the IAT probe back into the intake tract & do not get a CEL. But if the plug is diconnected from the IAT probe then you will get a CEL. Either way having a breather connected after the MAF is not good, that needs to be fixed A.S.A.P
1st: What brand intake did you purchase ebay, stillen, frankencar etc?
2nd: is the factory resonator (big black swaure box looking piece) still installed on the vehicle or did you new intake come with a replacement mid pipe?
3rd: What part of the midpipe are you capping off? Hopefully not the largest opening where the air intake bolts on. you should only be capping off one of the I think 5/8" openings?
I'll try to find some pictures for you, but first I need to know what intake you bought.
Does your new mid pipe look similar to this one?
http://pg.photos.yahoo.com/ph/likwid...&.dnm=7d1f.jpg
Or are you using the stock resonator like the one in this picture.
http://pg.photos.yahoo.com/ph/likwid...&.dnm=e3c5.jpg
Still intake.....custom midpipe, no resonator, i think we are confusing "midpipes" .....there used to be a small pipe coming from the top of the motor all the way to the stock resonator, instead of puting it into my new intake pipe, i put a breather on it.....that is why i am saying i should drill a hole into the pipe, get a fitting and put that hose into the hole....
the pipe im talking about is the one that is towards the top right under the first injen sign in red on the intake piping(black tube going to steal pipe sticking out) thats in this picture...
http://www.injen.com/webpages/intake.../rd/rd1930.jpg
Ok see how the red hose is coming off of the mid pipe & connecting to the valve cover? That is the correct way to hook it up if your not using one of those little breathers.
If your using a breather on the valve cover then the tube coming off of the mid pipe where the red hose is connected needs to be cap off so no air can be suck in. Everything else in that picture is correct.
Like this. http://pg.photos.yahoo.com/ph/likwid...&.dnm=e370.jpg
See how basically the other outlet from the mid pipe is not being used in this picture? Compare it to the original Injen pic you posted for me.
dude, there are two hoses going in...one from the valve cover and one more up top(the second one i put a breather on), i put a breather on the hose up top......and its a custom intake pipe, so i havnt put in any holes yet. This whole thread is just one big ol' misunderstanding.
Thats the best I can do for you, if that doesn't seem to help you understand how to cure the problem, then just take it to a mechanic because it's either one of 2 things something else is terribly wrong or you just can't comprehend how it should be. I'm not trying to diss or anything like that but this is not very complex work were talking about here. It's a friggin intake system...............
here I did the picture for you again so it is alittle clearer for you.
Notice the breather I drew on the valve cover.
Notice how theres only 1 area on the mid pipe for a hose to connect.
Notice how the hose that is connect to the midpipe is in "bright green" so you know it has to be connected. No breathers anywhere near that area.......
If you follow this picture your car will run perfect.
http://pg.photos.yahoo.com/ph/likwid...&.dnm=db33.jpg
maxima297
Sep 30, 2015 03:32 PM
